Results 1 to 7 of 7
Thread: Console bin illumination
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Default Console bin illumination
    I would like to instal the illumination in the console bin as per the Calais. Can anybody advise where I will find the plug for the wiring to connect to? Obviously, it's in the console somewhere, and I've had the cover off already, but couldn't find a spare plug socket which was obvioulsy for that purpose.
    I know that e-bay has kits, but $40 seems a bit rich when you consider what the kit consists of. I already have the light and switch and the wiring can be made up simply enough, I just need to know where it connects to.
    Can anybody help?
    Regards
    pj
    Mr_Calais's Avatar
    Mr_Calais is offline go the K's
    85 VK Calais and 03 VY storm ute 05 hilux
    Aug 2005
    hey just make up ur own wiring and find a powered wire eg- using the power socket (cigarette lighter) or something similer and jus make a good ground or also use an existing one. Ive done the same in my ust works fine no probs
    VY2 SS
    May 2004
    what switch did you use?
    VY2 SS, Redhot, SatNav, Sunroof, 18" J Type mags, D&T Performance Extractors, twin 2 1/2 S/Steel system.
    trentvy's Avatar
    trentvy is offline Dodges raindrops
    Vy S pack
    May 2008
    Kilsyth South
    From memory in my s pack I felt around in that hole were the light goes i felt some wires in there, wether its for the cigarette lighter i dont know.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Once you remove the top panel (where the window switches and accessory buttons are), look under there on the front edge of the bin - you'll see a connector which runs wiring to the cig lighter socket. (these would be the wires you felt trentvy) The thick black wire with the white trace is ground, and I can't remember the colour of the wire for the ciggy lighter +ve connection. (there is another brown/white wire in the connector, but this sin't the one you need - that's the illumination circuit for when the headlights are on)
    As for the switch, I'm not real sure - it's a pin switch of some kind, most likely available from Holden. It wouldn't be too hard to adapt something else though.
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    VY Berlina
    Apr 2007
    Wreckers would be the best bet, the switch and the light are the same as the glovebox one.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    in the kit, its a replacement loom for the cig light that has a piggy back plug that connects to the console light on the way to the cig/light switch. like you said not worth the $40 unless you need the light socket and switch aswell.
  1. illumination
    By dave0103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2008, 03:32 PM
  2. illumination
    By OZI51X in forum Car Audio
    Last Post: 13-09-2007, 07:27 PM
  3. VK Dash Illumination
    By Chode in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2006, 09:55 AM
  4. VK Dash Illumination
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2006, 10:30 PM
  5. No illumination in gear selection console on my VS
    By Hytes in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 02:51 PM
