Results 1 to 4 of 4
Thread: stereo acting weird
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Default stereo acting weird
    hi guys, just cruisin around on the weekend and my strereo switches started playin up, the car has sorted itself out somehow but just wondering if anyone has had it happen to them before and how they fixed it.
    basically all functions on the steering wheel worked except the volume down - pressing the volume down would turn the volume up, and everything else was fine so id use the wheel (either up or down) to crank it and have to turn the stereo dial to turn it down. i found it a bit weird thats all.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    This is a very common and well documented issue with VY's. Holden were replacing the steering wheel switches under warranty. I had mine done under warranty and haven't had a problem since. The switches feel much nicer to use too!
    I'd say you're out of warranty, so it's about $120 for Holden to fix it for you, or you can buy the switches and do it yourself. Do a search, a member here has done this himself for about $40-$50 from memory.
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    CANYONERO's Avatar
    Mar 2006
    Country SA
    cheers, i didnt know that this was the steering wheel problem, i thought it was switches ceasing to work and falling off etc.
    i'll look into it, i can get the switches for trade and have a crack at it myself.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    just remember to disconnect the battery and leave it for atleast 20 seconds before disconnecting the airbag so it doesnt set a code that you ahve to go to an auto elec or holden to clear
  1. iac issues? engine acting up
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 03:23 PM
  2. Weird Stereo Behaviour
    By cadburyvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2007, 10:35 PM
  3. Active Select acting up (i think)
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2007, 05:03 PM
  4. Fuel Guage acting weird
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 08:56 PM
  5. Air con acting crazy
    By Ms Stato in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2005, 12:17 PM
