Results 1 to 6 of 6
Thread: sticky accelerator
    vy executive
    Mar 2006
    Bacchus Marsh
    Default sticky accelerator
    Hi all when I first start my car the accelerator sticks but once I pump it once it is ok until I turn the car of again and re start it I have to do the same thing.I have sprayed some crc down the the cable but it did not make any difference.Has anybody had the same problem and if so how did they fix it......
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    May I sugest taking the intake pipe off the throttle body and inspecting where the butterfly is, they may be a build up of carbon and sticky black stuff which in turn slows the operation of the butterfly opening. Get some throttle body/ carby cleaner and shoot it at the butterfly and make sure you get in behind it and rub it with a rag, dont be affraid to give it allot of spray to get the gunk out. Also it may be caused inside the car, get some CRC and spray all the moving parts on the accelerator pedal and pump it a few times to make it all nice and smooth. Also CRC the moving parts on top of the throtlle body after youve cleaned it. See how that goes.
    RufusŪ's Avatar
    RufusŪ is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    Mostly likely carbon build up in the throttle body. Had it on the VX. Pull the throttle body off and give it a clean.
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    if you use throttle body cleaner on your car cleaning the butterfly dont worry if it takes a while to crank over this is normal.
    vy executive
    Mar 2006
    Bacchus Marsh
    Thanks for the replies guys i will try those things and I will let you know how it goes
    Vy Berlina V6
    Feb 2005
LinkBacks (?)
  1. 13-06-2008, 12:33 PM
  1. Sticky Accelerator Pedal
    By garywg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2008, 07:40 AM
  2. Accelerator Tight
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2006, 01:39 PM
  3. "sticky" accelerator
    By drewins in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2006, 11:31 AM
  4. Accelerator
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 01:39 PM
  5. Help with accelerator Cable
    By tristanwalz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 01:06 PM
