Hi, a question about the plug underneath the centre console that the optional cigarette lighter plugs into. There are three prongs, one is accessory power, one is dash light power, is the other one earth i take it? Thanks for your answer.
If there's 2 forms of power there, surely an earth would be required (I don't know what plug you're talking about, never looked).
Use a test light if you're unsure, i have used the plug but can't remember which is earth.
yes it would be for the earth
Yeh, thanks guys, i've got a test light, and i reckoned the third wire must be the earth.![]()
OT: in my new VY in the centre console box there is what appears to be a light... how does this turn on? i think my globe might be blown, is it hard to change?
just lever it out with a small screwdriver or knife and it takes a festoon globe!
Only if it's a Calais. Other models had a black blanking plug fitted in the console, which is a dead ringer for the lens , except the light isn't fitted. When you remove the plug, you can see that it is moulded exactly the same as the lens. Cheap bastards - they could at least have put a clear lens in all models instead of making a separate one in black plastic.
