Results 1 to 8 of 8
Thread: Factory sub VY R8
    vn hsv sv 89
    Apr 2006
    Default Factory sub VY R8
    Hi guys who can tell me where the factory POS sub can be found in my R8 might sound stupid but I can't find it, also does anyone know off hand what size the speakers are throughout, thanks.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    there should be 2 8 inch subs in the parcel shelf, i know that rockford fosgate do some pretty awesome replacement ones
    vn hsv sv 89
    Apr 2006
    What are the factory ones running off are they amped or does the head unit have outs?
    Boonz's Avatar
    Jul 2005
    they are only 50 watt subs, you can get high to low level RCA converters and run a power wire a small 2 chanel amp, my mate did it in his VX clubby and it sounded pretty bassy, he only used a 300 watt 2 channel amp
    vn hsv sv 89
    Apr 2006
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Quote Originally Posted by sik sv View Post
    I think they do have a small amp in the boot. I know the statesmans did so if the set up is the same then you should be able to find it in the boot.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Yes indeed, as NickVR suggested they do have a little amp mounted somewhere behind the trim in the boot. (I'm pretty sure....) I have one of these amps at home - was given to me by a mate who works in Holden spares. (it's broken, was replaced under warranty) I pulled it to bits and had a look out of curiosity, and found a pretty cheap and nasty amplifier solution to be honest. I wasn't the least bit impressed.
    It's not running from true low-level outputs either, it's driven by the speaker outputs from the head unit. Not really my preferred option - very much an "afterthought add-on".
    Might sound OK with some decent drivers mounted on the parcel shelf, but these head units are capable of so much better performance once true RCA outputs are added.
    Just my two cents worth!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. factory height
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2007, 09:34 PM
  2. Factory FE2
    By Calais3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2006, 01:55 PM
  3. Factory Tint
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2006, 10:54 AM
  4. factory vt stereo
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2006, 04:00 PM
  5. factory gas
    By kuffy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2004, 06:12 PM
