Hey Guys n Gals,
Found the info on how to make the tools to correctly remove my VY head unit, which I happly removed like 3 weeks ago. But now with the same tools I have having a bloody difficult time and can't seem to get the dam thing out.
Any ideas? If i remove the whole surround does it make it any easier to attack?
I am installing my new duel din dvd playerwoop!
I would try by taking the whole surround out. Can't hurt. If that doesn't work, buy the tools (look on ebay) or maybe a local dealership could do it for you. Good luck mate.
A Commodore is a passion. Anything else is just a car
i used a coat hanger for mine...
I used nails on my VT
50LTRv8
The coat hanger thing does work, but you need good stiff wire. Just push them in until you feel the wires click - this means the clips are pushed back.
The head unit can be pretty tightly clipped in (especially the wiring plugs) so you might need to apply a fair bit of force. Removing the whole centre console fascia only takes a couple minutes and 4 or 5 screws, so I would recommend removing it to apply more force.
It's really not difficult, but you have to pull a bit harder than feels safe for a few small bits of plastic. Give it hell!
yeh the trick is just to keep forcing the coat hanger in, dont be scared, you wont break anything.
