Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Do i have a LSD?
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    Default Do i have a LSD?
    Just got a VY Spack
    how can you tell if it is fitted with an LSD? is there a badge or something or does the diff look different?
    just wondering...
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    i doubt it, onli ss and the hsv range came out with lsd i think, u would just have a single pegger..
    always one way 2 check go out and rip a skid
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    1994 VR Wagon and 1997 VS Calais International
    Jan 2007
    Put the car on level ground
    Chock the front wheels
    Jack up the entire rear end
    Take the Handbrake off
    Now turn one wheel as if the car was driving forward
    If the other wheel turns in the opposite direction it isnt a LSD
    If you find you cant turn the wheel by hand its a LSD
    If you put the trans in Neutral and both wheels turn the same direction along with the drive shaft its a LSD
    if you still cant work it out crawl under the car and see if there is a tag saying its a LSD
    Stop looking for the Potholes and sit back and Enjoy the Ride
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    big m's Avatar
    big m is offline FIGJAM
    vslll v6 2000 olympic series ute, 1997 pajero 3.5l
    Sep 2006
    nsw
    look under the car from the rear and look at the center of your diff and then look up to the top right corner of your diff casing and you will see a big tag that will stick out like dogs balls if it has the tag you have LSD
    Homer: "for once in my life someone is calling me sir without (your making a scene)"
    Apr 2008
    ive looked under the car and it doesnt have a tag...
    but if i turn one wheel, the other wheel doesnt turn the opposite direction (i had it up on a hoist)
    Apr 2008
    Quote Originally Posted by big m View Post
    i might have another look,
    do LSD's look physically different to regular diffs in any way though?
    big m's Avatar
    Sep 2006
    nsw
    umm not to sure the only thing i have realy seen is the tag havnt bothered loking at anything else lol but yea no tag no lsd unless you are good with a welder and are handy at takin a diff off lol
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Zep
    Zep is offline
    2010 MY10 VE SS-V
    Apr 2007
    Stock it won't be fitted with an LSD and i doubt it would have had one put in as an option mate..
    VN S1
    Jan 2008
    Ripping a skid out wont always work, my stuffed diff did double lines on my driveway (cement) so i did a few checks as above and it wasnt, just the diff was stuffed lol.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Apr 2008
    Apr 2008
    Quote Originally Posted by DUK13Y View Post
    Why do you think you have an LSD?
    i just have a suspicion!!
  15. #15
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    search the words " the LSD thread" and select titles only. then on about page 2 you will c the thread. There are 10000000million lsd thread so just do a search and you will find what your looking for
    no longer a hoon by association - the commodore is gone
  16. #16
    Apr 2008
  17. #17
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    i wasnt having a dig at you mate, just letting u no about the "search titles only" thing. becuase without that the search function is pretty much pointless when it gives u 100,000 results to look through.
  18. #18
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    if its an exec, berlina, s pac, it wont have an lsd stock and are fitted with either 2.93? or 3.08 diff ratio. like others have said jack both rears up, if both spin in the same direction then its an lsd, if i spins the other way or not at all, its a single pegger.
  19. #19
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter!
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    It will be stamped on the diff
    There will be information like the ratio and the part number on the left hand lower side (drivers side) It will say LSD: Yes
    Attached Thumbnails Attached Thumbnails Do i have a LSD?-diff-20cover-20side-201.jpg
    VZ SSZ- LS1
  20. #20
    Apr 2008
    Quote Originally Posted by Banks View Post
    cheeers, im going outside right now to take a look
  21. #21
    Apr 2008
  22. #22
    BANKS's Avatar
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    Quote Originally Posted by VYsam View Post
    and PS, that is a bloody clean diff!
    hahah not my diff, its a harrop photo. I want to get the harrop sports diff cover and mount thou!
    how'd ya go?
    VZ SSZ- LS1
  23. #23
    FPV 4 T's Avatar
    FPV 4 T is offline myspace.com/attakarrak
    2008 VE HSV Clubsport R8.
    Oct 2007
    Just got a VY Spack
    just wondering...
    1. check the sticker on the diff... if you cant find it
    2. next time you change a tyre n the car is jacked up... spin one wheel by hand and if the other wheel on the other side spins the same way as the way your spinning the wheel.. you do! but if it spins the opposite way you don't.
    3. go rip a skid... hahaha
  24. #24
    Apr 2008
    righto, just had a look, the sticker doesnt say LSD anywhere, but it says ratio 3.08:1
    does this tell you anything?
  25. #25
    BANKS's Avatar
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    You have a 3.08:1 ratio, non LSD diff lol
    VZ SSZ- LS1
