Results 1 to 4 of 4
Thread: Coolant change
    VY Executive
    Dec 2006
    Default Coolant change
    Hi all
    My radiator has a small leak and I bought one of those stop leaks. But, the label says to drain out all the existing coolant and fill in new one with the stop leak liquid.
    Should I bleed the system after filling in the new one? if so, how do I do that?
    Suggestions appreciated.
    Thanks
    Borrow money from a Pessimist-They DON'T expect it back!
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by jyothi View Post
    Hi all
    Thanks
    You should always bleed the system after refilling. Im not sure where the bleed point is on your car, but it will be the highest point in the system, this should either be the radiator cap or I think there is a bleeding valve/screw located next to the thermostat where the top radiator hose meets the engine, have a look there. If there is a screw/valve, unscrew it while the engine is running to let the air out, also squeeze the radiator tubes to get air pockets out, when coolant starts to leak from the valve you can tighten it up again.
    VY Executive
    Dec 2006
    Thank you very much.
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    Those stop leak things are just a temporary bandaid. You should definitely get your cooling system pressure tested, there aren't that many compenents to it and cooling problems are generally pretty easy to fix.
    Do you know where the leak's coming from and how much is it leaking?
    Shounak
    Always Right
    My Ride
  1. coolant change.
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2007, 04:32 PM
  2. HELP! how do i change the coolant!?
    By judoman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2006, 06:34 PM
  3. coolant change
    By KIKE in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2006, 08:48 PM
  4. Coolant Change
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:39 AM
  5. Coolant Change
    By DJ Majah in forum General
    Last Post: 29-04-2004, 11:22 PM
