Results 1 to 4 of 4
Thread: Breather plug
    VY Executive
    Dec 2006
    Default Breather plug
    Hi
    Can anyone please tell me where the coolant breather plug?
    Thanks
    Borrow money from a Pessimist-They DON'T expect it back!
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    to bleed the system? on top of the thermostat housing under the engine cover,
    easiest way to bleed the cooling system (and i do this at work) is to remove the breather screw,
    grab a funnel and fill the system with coolant pushing the funnel into the cap seat so it dosnt leak, fill the funnel up so the coolant level is higher than bleeder,
    wait for the fluid to come out of the bleeder, allow a bit to come out, replace the screw and tighten, then remove the funnel, start the car, top up the radiator if the level drops,
    once the top hose starts to warm replace the cap, allow it to get to normal operating temp then just crack the bleed nipple to check for air (should be none to very litle if done properly that way)
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY Executive
    Dec 2006
    That was very handy, andyman or should we call you 'handyman'!!! Thanks a lot for that.
    How many litres for the radiator? 5 lts?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by jyothi View Post
    yeah 5lts of concentrate will do it, the whole system holds 10lts roughly, it needs to be mixed 50:50 coolant/water
  1. fuel breather hoses
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2007, 12:38 PM
  2. Breather Cap on VR-VS 3.8lt???
    By Frandy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2006, 10:48 PM
  3. diy crs pcv breather
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2006, 11:07 PM
  4. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
  5. Breather Hose
    By niggle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2004, 05:57 PM
