Gday,
I want to replace the factory fitted speakers in the my 03 Vy commodore with component speakers hence i have to buy an amp too. The only thing is i want to keep the stock blaupunkt headunit, but there are no RCA outputs to pulg an amp into. How can i fix this? How much will it cost? And thirdly will it decrease the sound quality if i do this instead of getting a new headunit.
****I am getting $600 speakers and a fairly expensive amp also.
Thanks
Hi, and welcome to the forum.
Try doing a search!!! as this topic has been covered more than a dozen times before.
Phreddy on this forum will be able to install RCA's into your stock VY Headunit.
Phreddy's Website is one of the sponsors on this forum ASR Electronics - Welcome to ASR Audio & Electronics Home Page
Pricelist for Stereo Mods from Phreddy - http://www.asr-audio.com.au/files/StereoMatrix.pdf
CHECK OUT MY RIDE
IF I WAS HELPFUL TOO YOU CLICK MY SCALES
"Girls are like domain names, all the good ones are taken."
you can buy fairly high powered amps that run off speaker connections instead of RCA...
Also jaycar sells the connector box from speaker to RCA for about 30 bucks
