Results 1 to 7 of 7
Thread: Remove Gear Shifter Bag
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    Default Remove Gear Shifter Bag
    Anyone know if it is possible to re-insert the bag which covers the auto shifter without removing the entire centre console... mine is pulling up at the edges and i want to stuff it back down.
    maginoodle's Avatar
    maginoodle is online now Donating Member
    vy series2 ss crewman
    Apr 2006
    yes it is possible. just pull the shift surround out and then you will need to pull the plate that holds the boot in place, put the boot into the right spot the put it all back together. i did the one in my crewy sometime last year.
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    Apr 2008
    Apr 2008
    maginoodle's Avatar
    Apr 2006
    use this link http://forums.justcommodores.com.au/...sole-vy-vz.htm it is in your other thread How to remove VY centre console. have a look at the underside of the surround and you will see how it goes together
    Apr 2008
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    shouldn't take that long. If you want it done right, you will have to spend that extra time.
    A Commodore is a passion. Anything else is just a car
  1. How To Remove Steering Wheel And Gear Shifter
    By Troy711 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2010, 06:36 PM
  2. How to remove VT-VX Shifter
    By SIXAPPEAL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-07-2006, 11:48 PM
  3. Gear shifter loose?
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2006, 11:12 PM
  4. Vt Auto Gear Shifter On Vs
    By vscommy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 06:06 PM
  5. Changing Gear Shifter
    By dion in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-11-2004, 12:27 PM
