Results 1 to 10 of 10
Thread: Remove stering wheel front.
    ozzie_online88's Avatar
    ozzie_online88 is offline I'm No Superman...
    2003 VY S1 Exec
    Sep 2005
    Adelaide, South Australia
    Default Remove stering wheel front.
    I have had a look through all these forms, and I couldn't find anything on this. I want to remove the front (what you press for the horn) of my steering wheel so that I can hopefully remove the rubber/plastic bits in between the center and outside of the wheel to paint them silver like in the picture attached.
    Does the front just pull off? Clips? Anything I have to worry about to do with the airbag?
    Attached Thumbnails Attached Thumbnails Remove stering wheel front.-attachment.jpg
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    its a part of the airbag and it has to be removed with specific tools by holden
    2003 VY S1 Exec
    Sep 2005
    so no way around this? has anyone successfully removed and painted theirs?
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    This thread, which you have posted in i see, will tell you how to remove the wheel.
    http://http://forums.justcommodores....heel-vy11.html
    If you're not confident then you should take it as mentioned to holden, but they are quite easy to do if you follow those instructions.
    2003 VY S1 Exec
    Sep 2005
    Nov 2005
    Warrnambool
    Quote Originally Posted by ozzie_online88 View Post
    Ahh dang, I was hoping I did not have to strip it down that far.
    It really is pretty straight forward, also it's hardly worth painting them imo, they're available through holden for $35 for the set.
    2003 VY S1 Exec
    Sep 2005
    Yeah but considering i am going to paint my whole center console, I figured id have the paint n primer ready to go. Plus either way it sounds like im guna have to strip it down that far.
    Nov 2005
    Warrnambool
    2003 VY S1 Exec
    Sep 2005
    heh. Well if I wish to purchase a set, what is the GM part number? On another thread no one could get a part number for the silver ones. Not that I saw neways.
    vy ss ute
    Jul 2008
    to remove the horn pad first u take out the horn & srs fuses, (panel above the pedals) also have the key removed from the ignition, this is all 4 safety.
    unhook the 4 clips from behind the str wheel with a flat blade its abit tricky, it helps to bend the tip a bit.try to pull the horn pad with one hand and unclip with the other. good luck mate
LinkBacks (?)
  1. Remove VP Steering Wheel
    By Glen_P in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2008, 07:15 PM
  2. How to remove wheel stud?
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2008, 07:56 AM
  3. will a vt stering wheel fit a vr
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2006, 10:11 PM
  4. ISOTTA NIVOLA DSX stering wheel
    By GH05T in forum Parts And Other Items For Sale
    Last Post: 10-11-2005, 01:05 AM
  5. VX Stering Wheel Removal
    By Sparkyab in forum V6 Development And Modification
    Last Post: 18-08-2005, 07:00 PM
