Results 1 to 20 of 20
Thread: dropped a bolt in the intake plenum/manifold help!!!
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    Default dropped a bolt in the intake plenum/manifold help!!!
    Hi, I was putting in a plenum spacer and manifold insulator and dropped a bolt down the manifold or plenum or wateva ya call it lol I know it will kill the car if I run it with it in there. How do I get it out??? I dropped it in the front port I have removed the passeneger side rocker cover and rockers but can't see it. What else do I need to do to get to it?
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    Maybe try some sort of Magnetic Extension thingy to try to get it.
    I bought a Extendable Magnetic Rod a few years ago.
    It looks like a Pen which extends like a car antenna and has a magnetic tip.
    This may do the trick.
    Comes in handy when I drop bolts/nuts in the engine bay.
    Bought it from Bursons.
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    Awesome I will have to try that I think they where galvanised so I don't know if there magnetic any other ideas
    Cursed CX8 is offline Banned
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    you can get similar things to the magnetic ones. But they have a claw on the end. So you would push it down the runner, then close the claw and retrieve. Its a great invention lol
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    A galvanised bolt is still magnetic - the bolt itself is still made from steel.
    Also, lifting the rocker cover won't get you access to the port - only the rockers and pushrods....
    I reckon you'll do OK with one of the magnet pick-up tools that oztech suggested - but them claw tools are great too, huh Class Calais???
    All the best with it. Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I dropped a injector pintle cap down the injecor hole once, I got it out with a vaccume cleaner and a roll of duct tape and a hose. Get a smalish hose and tape it to the end of the vaccume and stick the hose down into where you think it is.
    vy ss ute
    Jul 2008
    Trythe tip of the pen magnets attacthed to rubber hose. same thing happened to me
    Gudgeon's Avatar
    Gudgeon is offline NE1 4SX
    VR Exec S2 and VK 333 Pack Calais
    Jul 2008
    Mount Gambier
    If you haven't got a magnet handy, a long steel rod with the an old speaker on it will do the trick
    There's No Replacement For Displacement
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    as said already, get yourself a magnetic rod - i've got a "snap on" brand one which ive used before to get a plenum bolt out of the runners before and it worked a charm - very easy to remove the bolt with it.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    u could avoided this if u.....didnt drop the thing in ur engine...next time u will learn
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    ivaninoz's Avatar
    ivaninoz is offline Ivaninoz
    VS SerIII Statesman
    Nov 2006
    Millmerran, on the Downs, Darling
    Quote Originally Posted by Gudgeon View Post
    Or try this with a Plastic Sleeve on the Rod.
    It won't try to latch on to every Ferric thing else on the way down.
    Ivan in Oz,
    Over the Hill, SEQld
    MOTOGuzzi T4 and Cali III Dresser
    1985 735i Bemmer............
    1998 Statey......
    ivaninoz's Avatar
    VS SerIII Statesman
    Nov 2006
    Quote Originally Posted by Mack View Post
    This is what I use when cleaning out Holes in Concrete, where I bolt down Walls.
    Suprising the size of some of the bits one can drag up with the Vacuum.
    BIG Tick
    Ivan in Oz,
    1998 Statey......
    Sep 2006
    Just pull off the intake manifold. You'll need new gaskets that's all. Rather be safe than sorry.
  15. #15
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by VRSLT323 View Post
    umm, no shit..?
  16. #16
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by AttaBoy View Post
    Pffft..start the car it'll back out the exhaust...LOL
    (DON'T do it!!!!!)
    Best suggestion so far. Just remember to give it a big rev so it will come out quicker.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  17. #17
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    Thanks guys metal rod worked and I knew it could possibly happen I had covered the holes up with a towel the whole time exept wen I was putting the bolts back in lol cause I needed it out the way to get them in so yeah I dropped it then sucks hardcore and thanks for the sarcasm guys very helpful
    1.91 rockers, 69mm throttle body, bmc panel filter, electronic shift kit, plenum spacer, manifold insulator, pioneer 7inch 6 stacker dvd player, 2*12inch subs- custom fibre glass boxes
  18. #18
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by Elite58 View Post
    hey man, if you post the stupid **** you do then dont be surprised if you cop a bit!
    lol
    good to hear you got it tho...
  19. #19
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by garfa View Post
    lol
    what was stupid about his post?! geez some people have their head up their ass around here for christ sake.
  20. #20
    VS Acclaim V6
    May 2005
    Quote Originally Posted by sircruisealotVS View Post
    LOL haha...
  1. intake manifold/ plenum for v6
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-05-2008, 09:15 PM
  2. VT V6 Top End. Heads, Intake manifold, Plenum chamber, Throttle body.
    By VSO.38 in forum Parts And Other Items For Sale
    Last Post: 23-11-2007, 03:55 PM
  3. Bell mouth fitted to plenum on intake manifold
    By lexand in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-06-2006, 03:47 PM
  4. Divided Plenum Manifold HOW-TO
    By greenfoam in forum Holden Commodore How-To's
    Last Post: 17-02-2006, 08:13 PM
  5. WTB: S1 VT V6 top intake plenum
    By chevy_big_block_bro in forum Swap / Wanted to Buy / Trade
    Last Post: 19-10-2005, 07:53 PM
