Results 1 to 5 of 5
Thread: VY Tonner LED taillight conversion??
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question VY Tonner LED taillight conversion??
    The taillights on my parents' VY Tonner are useless. Cheap aftermarket ones.
    Looking into the full LED taillight setups that you see on a lot of trucks around the place, the auto sparky says they're horrendously difficult to install, problems with cruise control, indicators etc etc. meaning they'd have to replace some relays along with other stuff.
    Are they clueless or is this a valid issue?? Complicated?
    Sam
    WTB: mulberry VN interior parts
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    It's true. If you replace your brake lights with LEDs you need to add "dummy loads" (simply some resistors of the right value in parallel with the lights) so that they draw the same amount of power/current as the old incandescent lights, otherwise the cruise control will act up.
    For the indicators you need to change the flasher (for the lack of a technical term) otherwise the indicators will flash too fast.
    I can't see how it's terribly difficult to install though?
    The maths for the dummy loads isn't terribly difficult for someone familiar with electronics.
    E.g. If you are replacing say a 20W globe with a 3W LED replacement you need a 17W dummy load:
    Assuming Voltage = 12v
    Voltage = Current*Resistance
    Power = Voltage*Current
    Work out required current for the load:
    Current = Power/Voltage = 17W/12V = 1.42A
    Work out the resistance needed:
    Resistance = Voltage/Current = 12V/1.42A = 8.45ohms
    It is easy to find a resistor around 8.45ohm, but not one that will handle 17Watts, so a few in parallel will need to be used. Two resistors in parallel will act like one big resistor with half the resistance and handle twice the load. So two 10Watt 17ohm resistors would work as one 20Watt 8.5ohm resistor, and that how you make your dummy load for each light . Jaycar stock 10W resistors suitable for the application.
    Supercharged VU SS
    Feb 2006
    The Shire
    are you sure about the indicators, i just swapped my side indicators over to wm caprice LEDs, but to drive the car to the painter and back it didnt have any side indiactor at all and the front and rear still flashed at a normal rate, not the usual flashing really fast like i thought it would,
    BUT50 is offline BUT50
    VX Executive S2-VN SS
    Mar 2007
    TTM is correct I had issues with my tonner a couple of years ago but got it sorted it isnt that hard
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK so there's a bit of playing around... Will have to try another auto elec as this one quoted over $250 in labour alone.
  1. condensation in my taillight
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2008, 02:50 PM
  2. VN headlight and taillight
    By danos in forum Parts And Other Items For Sale
    Last Post: 20-04-2007, 11:23 PM
  3. SLE taillight extensions
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2006, 10:15 PM
  4. VL taillight tint QU
    By Sabby in forum General
    Last Post: 26-10-2006, 07:25 PM
  5. WTB: VS-VR Taillight
    By Righty in forum Swap / Wanted to Buy / Trade
    Last Post: 27-02-2005, 09:36 PM
