Results 1 to 8 of 8
Thread: VE GTS 20"s on VY S pak ute?
    VZ Commodore
    Mar 2008
    Shepparton, Victoria
    Default VE GTS 20"s on VY S pak ute?
    Just wondering if these would fit a Vy s pACK UTE. As the rears are 9.5 inch wide? Any help?
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Don't worry about the 9.5 rears. Just get 4 fronts and you will be ok. But the centres will have to be machined.
    VZ Commodore
    Mar 2008
    Jemmo5ltr is offline Adrian
    VY Berlina
    Jun 2008
    id look into it a bit more i think VE rims have different stud pattern and dot fit any other commodores
    Oct 2006
    Bogan enclave
    Quote Originally Posted by Jemmo5ltr View Post
    Stud pattern is not different, centre hole has a lip which needs to be machined out.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Oct 2006
    Bogan enclave
    Quote Originally Posted by Jesterarts View Post
    ^^^ Different offset too aren't they?
    Hence the maching!
    Plenty of VT-VZ Commodores getting around with VE wheels.
    Studs on VE are also 1mm thicker but will still go on previous models with no problems.
    VZ Commodore
    Mar 2008
    Quote Originally Posted by Bravotwozero View Post
    Yer that right cost about $100 from wheel joint to do all for wheels.
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  2. Starcorp Impul Wheels 18"x8.5" and 18"x9.5" Adelaide
    By vs_ss_matt in forum Parts And Other Items For Sale
    Last Post: 24-05-2008, 06:43 PM
  3. Vic Number Plates - ""LINUS1""
    By pugga in forum Parts And Other Items For Sale
    Last Post: 04-02-2008, 11:01 AM
  4. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  5. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 08:59 PM
