just wondering if anyone knows if the lumina has an alarm and apparently there is a spec way to turn the alarms on or some**** apparently u press lock twice just wonderin if its true.
thanks fellas
Yes you press lock twice within 10 seconds. The indicators with then light up and stay on for a few seconds. The car is now deadlocked and the alarm is activated. Cool thing about it is that if the alarm is tripped, when you next turn the ignition on, it will display in the cluster where on the car the alarm was triggered. (Doors, boot, bonnet etc etc. )
Does this on my SS but if you're not sure if the Lumina is the same, deadlock the car then pop the boot and it should go off.
alright cool thanks mate
just tried that it didnt work than i had a wonderful idea why not check the manual it said u can open the boot with out the alarm goin off maybe i should just shake the thing till i find out
pop your bonnet, close and lock your car then open the bonnet. scared the S*** outta me coz i found out by mistake!
hahah alright thanks mate
just tried it didnt go off i guess i dont have an alarm than i thought i would but yeah guss i dont
mine took like a minute or two before it went off. i thought Vy came with them factory.
thats what i thought but yeah maybe i should leave it open a bit longer it deff deadlocks well i think it does cause i press lock the second time and the indicaters and **** stay on for a couple of secs and than go off maybe i should leave the bonnet open longer
look for a bonnet pin under bonnet in the middle near the lever
look for horn on pass side firewall
if both present you have an alarm
if not present you dont
thanks for that will do
Lock your car with the remote. Alarm should now be activated. Now open your door with the key without using the remote. Once your door is open the alarm should sound within a few seconds. Alarms were standard on the base models since the VX (not quite sure if series one or two). Anyway give it a go!
thanks for that will try it in the mornin
hey guys thanks for the help deff have an alarm lol put the key in and turned it when it was deadlocked **** that scared the **** out of me hahahhaa thanks to u mmrdb hahaha thanks for the help guys
Is this the same with the VX?
