| VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore. |
05-08-2008, 11:09 PM
Ride: vy ss commodore 5.7ltr
piston slap in vy gen3?
hey everyone, piston slap in gen3 vy's is it still a problem? and how do you tell if you've got it? i spoke to holden bout 12 months ago and they said it was nothing, and it sounded a bit like lifters, but the last month or so its become more an engine rattle and louder than a lifter noise, could this be piston slap and is there anyone in melbourne that has good experience with gen3's that could help me out with diagnosing this problem?
any help greatly appreciated.
06-08-2008, 11:03 AM
da da daaaaa da da daaaa
Ride: 5 litre barge.
i havent heard anything of piston slap in vx onwards.... was just in the vt as far as i know.
06-08-2008, 01:18 PM
Ride: 'Enhanced' Y Series Senator Sig
mate, does it do it on cold start?
Go check all your plus are tight
__________________
minuxx dot net
Buy my Prints below
06-08-2008, 03:10 PM
Ride: MY08 Outlander XLS
What oil you using? The LS1's don't like a too thin an oil, they rattle.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS
Wholesaler of exhaust, suspension and brakes.
06-08-2008, 03:30 PM
Quote:
they also don't like a loose spark plug...had me stressing that new lifters would be needed
__________________
minuxx dot net
Buy my Prints below
06-08-2008, 03:54 PM
Haha...did them up with girls hands huh?
__________________
06-08-2008, 03:58 PM
Apparently, was only 1 loose, but damn it sounded bad. Worse thing was, it was something i didn't even think to check.
__________________
minuxx dot net
Buy my Prints below
06-08-2008, 10:55 PM
Usually what you least expect.
__________________
06-08-2008, 11:25 PM
spark plugs should be tight, i'll check them though, thanks minux.
not_an_abba_fan, i'm useing castrol edge 5w30, its done 167,000kays now, yeh only on cold start as it warms up it seems to go away.
07-08-2008, 01:22 AM
Ride: VP Executive R-spec
They all rattle on 30 weight oil while cold, any engine that big with big clearances will until it warms up and the pistons grow a bit, that's just how it is. The Fords do it too
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
5-12-08 Friday night street drags can 8.99/13.99 be done on a 2.5 inch exhaust? that is the question that will be answered
Download the flyer for the next street legal drags
http://www.southcoastraceway.com/ima...dec-5-2008.pdf
My VP, going fast on the cheap
07-08-2008, 06:52 AM
Quote:
Nope, mine does not have one single rattle, never did, ran on 10-30 all its life until last oil change.
__________________
minuxx dot net
Buy my Prints below
07-08-2008, 04:02 PM
The majority of them do rattle when cold. Holden say to use the thin oil to achieve economy, but I would use a thicker oil. Go with a 15W40. Try to stay away from an oil that has too big a gap between the numbers. These have more additives to achieve the higher viscosity. These are what break down and make the oil really thin. 15 as the cold rating is ample. Regardless of what commsirac says.
__________________
07-08-2008, 09:03 PM
