The wheel shudder at a particular speed is probably just a wheel that's out of balance or alignment - this is very simple to fix.
The whiny noise during low speed turning is almost certainly coming from the power steering pump, which might be running low on fluid, or perhaps becoming worn out. Check the fluid level first, and if that's not the problem, ask a mechanic to check it out.
LinkBack URL
About LinkBacks
