+ Reply to Thread
Results 1 to 5 of 5
Thread: VY II Calais
    vq statesman
    Nov 2007
    Default VY II Calais
    Hey Guys Just wondering if you might be able to help me out,
    I have 2 Issues,
    I hear this noise now under my dashboard like somethings opening and closing when the cars turned on and again when its turned off... Any Ideas what it might be.. Never heard it until today.
    and Also when I turn the Car off the The Backlight and Clock stay on the Cd player display and can be turned on and off without the ignition to acc..
    Some help and Ideas Greatly Appreciated
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash DUK13Y Executive
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    The clock and radio will stay on when the car is turned off and key is removed until the driver door is opened. Hope this helps a bit.
    A Commodore is a passion. Anything else is just a car
    vq statesman
    Nov 2007
    Default Thanks
    Thanks that does help,
    But when the door is opened it doesnt shut off so im guessing a slight electrical hiccup with a cut of switch or something?
    any other advice on these points please?
    cheers thou!!
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum Calaber W427 Calaber W427 Calaber W427 Calaber W427 Calaber W427
    VY II BERLINA
    Nov 2007
    LOwer Hunter Region NSW
    The noise you refer to is possibly an air vent or door in the air con being activated by vacuum when the engine starts and stops. Not sure that it should do that, but if the air con works correctly, why worry?
    GMMAD's Avatar
    GMMAD is offline 12 sec club GMMAD Executive
    VXSS camed LS2,3.8 GT35 4runner
    Dec 2006
    Nowra
    check the switch in the door jam and see if it is stuck on or it may be stuffed
    cheers GM
+ Reply to Thread
  1. vx calais to vy/vy calais front end conversion
    By dijm8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2008, 07:09 AM
  2. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  3. Replies: 57
    Last Post: 12-10-2006, 07:47 AM
  4. WTB: stock VK calais / VL calais headunit
    By DaRiO in forum Swap / Wanted to Buy / Trade
    Last Post: 16-05-2006, 10:03 PM
