if it dripping off the lower radiator shroud check the coolant isnt running back across from the bottom hose - seen that, and check that you havnt picked up a rock in the radiator,
either way take it back to who ever serviced it and tell em to check it.
LinkBack URL
About LinkBacks
Water pump is fine, Radiator hose is not worn and is clamped on tight. When i look under the car there are 3 small holes under the plastic guard which is underneath the radiator and this is where the water gathers then drips. I tried to look for a bung but could not find one because.. they may have not done it up all the way? But they didn't say anything about changing my water. Thanks.
No point taking it back as they will just say it was fine when you left.
