Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack (1) Thread Tools Display Modes
  #1
Old 30-08-2008, 09:56 PM
744driver's Avatar
Ride: Airbus A380-800
Trade Rating: (0)
744driver Executive
Default Yet Another VY Foglight Problem
I have a VY series 2 S with genuine foglights
It has Genuine foglights which i assume came stock
The problem is that they do not turn on unless i put the high beam on, they do not come on when i turn the headlights on.
Most of you will say, why dont you pull the switch outwards as this will turn them on, this is the switch i have:
and no, it doesnt pull outwards.
When i look under my car i see these loose wires:
Can someone help me to get these damn things to activate when i turn the headlights on? These parts where all pre-installed in my car, and appear to be 100% genuine, i just dont know why the wont work on low beam...
Thanks for any help.
__________________
FOR SALE
MTX 12" SUBWOOFER
http://forums.justcommodores.com.au/...tml#post829819
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 31-08-2008, 06:27 AM
Calaber's Avatar
Contributing member
Ride: VY II BERLINA
Calaber Berlina
Those two loose wires are for the second horn. Fitted to most Commies, I think, but only used in Calais upwards unless second horn is optioned.
Obviously the wrong light switch, and I'm not sure that they are genuine lights. They are not the same as my Berlina and all VY fog lights were the same, regardless of whether they were fitted to SS, Berlina or Calais, so it seems that your car has been fitted out by a previous owneer. You could probably swap the switch feed from the high beam to low beam at the back of the switch, or try buying the correct switch which is only about $47.
  #3
Old 31-08-2008, 11:28 AM
Ride: VY s m5
0081 Executive
Get your self a new swtch mate
  #4
Old 31-08-2008, 11:38 AM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
Who ever wired them, did them as driving lights, which can only come on with high beam. Fog lights come on with parkers, so you have to change the feed wire from the high beam circuit to the park light circuit. My guess is they have a separate switch somewhere? If not and they come on whenever high beam is turned on they are illegal anyway. You need to have a separate switch, whether it is a toggle or the genuine switch that can be pulled out.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Wholesaler of exhaust, suspension and brakes.
  #5
Old 31-08-2008, 08:50 PM
744driver's Avatar
Trade Rating: (0)
744driver Executive
How do you change the wiring from hi beam, to parker? sorry i suck with auto electrics.
__________________
FOR SALE
MTX 12" SUBWOOFER
  #6
Old 31-08-2008, 09:11 PM
Trade Rating: (0)
You need to find the main feed wire that is spliced into the high beam wire at the headlight and move it to the park light.
__________________
  #7
Old 31-08-2008, 10:00 PM
744driver's Avatar
Trade Rating: (0)
744driver Executive
at the head light or the foglight?
__________________
FOR SALE
MTX 12" SUBWOOFER
  #8
Old 31-08-2008, 10:34 PM
Trade Rating: (0)
The headlight. There should be a wire that connects to the high beam wire on one side. That should go to a relay. But then again, if you don't have a separate switch, it may be just wired directly to the fogs.
__________________
  #9
Old 31-08-2008, 10:54 PM
744driver's Avatar
Trade Rating: (0)
744driver Executive
do you know if the lights are genuine?
__________________
FOR SALE
MTX 12" SUBWOOFER
  #10
Old 31-08-2008, 11:09 PM
Trade Rating: (0)
No idea. The SS in the lens suggests they are, but I'm not sure.
__________________
  #11
Old 01-09-2008, 06:47 AM
Calaber's Avatar
Contributing member
Ride: VY II BERLINA
Calaber Berlina
I don't think they are genuine. As I said earlier, the lights are the same, regardless of whether they are fitted to a Calais, Berlina or SS and my Berlina lights lenses dont have SS on them. They have some form of identification moulded into the very bottom of the lens, just inside the bezel.
  #12
Old 01-09-2008, 10:22 AM
Donating Member
Ride: Cammed Y-Series Clubsport
Farlig Executive
genuine method for fog lights to activate are, when lights are switched to parkers/normal you can pull the light switch outwards and fogs turn on, together with the fog light symbol on the dash.
a few members have installed the genuine method, basicly purchase the genuine switch and relay the fog lights.
having them turn on with high beams is absolutely useless thou, serves no purpose to aid in "fog" conditions
  #13
Old 01-09-2008, 06:46 PM
744driver's Avatar
Trade Rating: (0)
744driver Executive
Damn are you telling me my lights are fake?
__________________
FOR SALE
MTX 12" SUBWOOFER
