+ Reply to Thread
Results 1 to 4 of 4
Thread: VY 3 Window Dash Cluster
    VT Calais
    Apr 2007
    Default VY 3 Window Dash Cluster
    Hi All
    can a berlina/calais/statesman cluster fit straight into a ss ute??
    do i need to change to a lux level BCM?
    im going from a vt calais to a ute and ill realy miss the L/100km thing.
    thanks
    vy v6 acclaim
    Apr 2005
    It will and you don't have to upgrade your bcm. I put one in my vy s1. Check what colour plug is on the back first, grey s1, blue s2. If you put a s2 cluster into a s1 car your fuel gauge will work back to front and you the digital display won't show milage properly (a s2 fuel sender is required to remedy this) or the other way round (s1 into s2). Your holden dealer can reprogramme the cluster to suit your car (tech 2) but can't change the milage after 100,000 k's. Companies like namiis (www.namiis.com.au) can reprogramme the milage of the new cluster to suit what is on your old cluster for about $130.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa Doctor Bob GTO Doctor Bob GTO
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by davfull View Post
    almost right, grey plug is VY blue is VZ
    series 2 fuel senders are not all reversed, most utes are & only some sedans. very few wagons seem to be.
    the configuration can be set with a tech 2
    the odometer cannot be altered by the dealers if its over 100 km NOT 100,000
    there are other places that can reset the odo as well...
    Rob
    VT Calais
    Apr 2007
    thanks guys
+ Reply to Thread
  1. 1 window dash cluster to a 3 window?
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2007, 08:45 AM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 02:28 PM
  3. Replacing 1 window cluster with a 3 window
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 03:25 PM
  4. 3 window dash cluster
    By supercharged_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2005, 08:55 AM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
