Results 1 to 7 of 7
Thread: VYII Climate control vacuum leak help
    VYII Berlina Int Wag 6cyl
    Sep 2008
    Default VYII Climate control vacuum leak help
    My Berlina will divert the vent fan to the windscreen when the car is under load (say going up a slight hill). It seems to be a fairly common problem and searching through various forums there is a suggestion to change the black & white plastic valve just behind the engine block which I did but it didn't fix the problem.
    So I assume there must be a vacuum leak somewhere else.
    Has anyone got any suggestions or pointers as to how I locate this?
    Any help is appreciated. Cheers.
    VY2 Berlina
    Jun 2008
    Castle Hill
    i find my car will divert the vent fan to the windscreen when the car is 'on' (without starting the car), and randomly when driving, for like 10 seconds at a time
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by cewing View Post
    i find my car will divert the vent fan to the windscreen when the car is 'on' (without starting the car).
    Mine does that, but no issues when the car is running.
    Sep 2008
    My guess is that without the motor running there is no vacuum. But if it does it when driving then there is a vacuum leak somewhere, apparently.
    Sep 2008
    Vy Berlina wagon
    Oct 2008
    Default Climate control vacuum leak
    I have the same issue with mine and apparently it is a $20 part from Holden which is in behind the climate control. Holdens have said there is 2 there so your better off replacing both at the same time. But you do have pull the dash apart to get to it.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by vywagon1 View Post
    it will be an actuator, if you cant work out which one it is replace both, they are on the bottom of the case, not easy to replace but not too bad
  1. Climate Control Vacuum Probs VY Calais
    By oztech007 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-09-2011, 06:52 PM
  2. Vacuum Leak?
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:39 AM
  3. help with a vacuum leak
    By iillstevellii in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 09:55 AM
  4. Vacuum Leak
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 01:33 PM
  5. Vacuum Leak???
    By mazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2005, 02:53 AM
Tags for this Thread
