Results 1 to 2 of 2
Thread: Multi-function window
    Vy Ute 3.8
    Jun 2005
    Default Multi-function window
    I was driving to work this morning and all of a sudden, everything in the multi-function window came on. It is all still on when the ignition is turned of as well. Has anybody else had this problem or know of a reason for this?
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hmmmm - I've worked on quite a few VY and VZ clusters, and never come across this...
    However, it may just be that the micro inside the cluster has its knickers in a bit of a knot. It's not that hard to get to the back of the cluster and remove the harness connector for a few seconds - two #2 phillips head screwdrivers, a stubby and a "normal length" one, are all the tools you'll need.
    Start by releasing the column lock and drop the steering column down. Use the stubby screwdriver to remove the two screws holding the bezel - they're upside down in the top part of the bezel. Once these are removed, you can pull the bezel along the top edge and it'll pop out.
    Again use the stubby driver to remove two upside-down screws from the top cluster mounting tabs, and the regular driver to remove the two screws at the bottom.
    Now swing the cluster out from the top edge - before too long you'll be able to see the harness connector - it has a little release lever which you need to swing upwards, and this will pull the plug out for you. Wait a few sesconds, and plug it straight back in. Press it in firmly and the release lever will lock back down.
    That might fix it, but if not it might mean a trip to Holden. If it does fix it though, you've probably saved yourself a hundred bucks or more! (I'm sure the "friendly" service staff at your local dealer would charge at least that much...)
    Putting it all back together is obviously just the reverse procedure.
    Hope it helps. Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. Multi guage tacho
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2007, 07:25 PM
  2. search function
    By gopher in forum Site Feedback / Site Problems
    Last Post: 30-01-2007, 04:43 PM
  3. Multi-valve engine
    By vnberlwagon in forum General Discussion
    Last Post: 27-05-2006, 02:34 AM
  4. Legal to have multi-coloured car?
    By VS Omega in forum General
    Last Post: 02-04-2006, 07:46 PM
  5. Multi light dash?
    By bangers in forum The Pub
    Last Post: 25-01-2006, 03:35 PM
