Results 1 to 5 of 5
Thread: Need to fix a few little things on my commodore vy, advice appreciated plz!
    Sep 2008
    Default Need to fix a few little things on my commodore vy, advice appreciated plz!
    Hey guys, ended up buying a silver vy lumina, looks great had it checked out by my mechanic and he said it was in great shape but just needed a few little things to fix up... Hoping i can do those myself, so if anyone knows how to or if you recommend against it i would greatly appreciate it...
    -The rear dif oil needs to be changed...
    -The rear gearbox seal needs to be changed.
    -the radiator needs to be flushed and new coolant (i heard this is quite hard on this model cause the cap is hard to reach or something?) also what coolant should i use?
    -and its idling a little bit rough, its not bad or anything but i was wondering what i could do about that? The injector leads have all been checked.
    Thanks heaps for any replies.
    Regards,
    Korrupt
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    diff oil is quite easy. just drain and refill.
    Oh i forgot to mention it takes bloody ages to pump the new oil in.
    I radiator flushed mine and it was way harder than doing it to a falcon.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    take the car for a good hours drive to do the diff....
    once the diff oils warm you can drain it by loosening the top bolt first to let the air in then un screwing the bottom to let it drain. once drained do the bottom bolt back up and fill it from the top, when oils about to flow from the top bolt its full so do it up hand tight.
    the easiest way to flush ur radiator is to undo the top & bottom hoses then get ur garden hose and chuck it into the top hose to let it flush it..( same for the engine block) it may pay to remove the thermostat as it can stop the flow
    gearbox seal can be tricky and probebly easier and safer to get a mechanic to do it (shouldnt cost much and te seals are only $15)
    I could be wrong so this is a guide only hope its helpful
    Sep 2008
    Thanks guys,
    well the mechanic is a friend of the family so he quoted me $250 to do all 3, does that sound pretty reasonable? I'm thinking if its not a lot more than buying the stuff and fitting it myself it might be easier to let him do it... The gearbox seal is the thing i'd definitely get done by him and i'm guessing that part makes up the majority of the $250?
    Thanks again
    wetwork65's Avatar
    wetwork65 is offline A wet business
    VY Berlina V8 & VZ Adventra LX8
    Mar 2006
    With the goblins in South West WA
    Mate - that's a bargain. Cost me $350 just to have the gearbox seal done at Holden in ******* WA
    (can't mention business names)
  1. Some advice would be appreciated.
    By kinephantom in forum General
    Last Post: 11-08-2008, 08:11 PM
  2. Advice on new sound system for VX Commodore
    By jtu55493 in forum Car Audio
    Last Post: 14-12-2007, 12:52 PM
  3. Advice Buying Commodore SS
    By Sarkis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2006, 01:34 PM
  4. Commodore V8 - buying advice wanted
    By NZv8fan in forum General
    Last Post: 03-02-2006, 10:49 AM
  5. 81 Vh Commodore Carby Advice Sought
    By rossbl in forum Site Feedback / Site Problems
    Last Post: 07-03-2004, 07:39 PM
