Results 1 to 8 of 8
Thread: Converting S pack to LPG
    2010 Voodoo Sv6
    Sep 2008
    Default Converting S pack to LPG
    I'm looking at converting my 2002 S1 S to LPG.
    I have read plenty of threads on this and have decided to go for the factory fitted IMPCO. If anyone could give me advice on anything to do with the conversion i would appreciate it.
    Does anyone know a trusted fitter? Northern Brisbane/ sunny coast
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    Feb 2007
    Here are things to do before the conversion.
    Make sure the engine is serviced and running to it's full potential on petrol. Change the oil, ignition components (see below) and coolant (if need be).
    Get new spark plugs. Cheap ones are probably the best (read on for more details). Gap them to 0.8mm (this is vitally important for best driveability and economy with mixer-based gas systems). Even though they typically last longer, iridium plugs aren't recommended as they cannot safely be re-gapped and it is easy to forget when you originally installed them (bad!!!). Replace them every 10,000-15,000km and you should rarely experience a backfire. At $2 a plug or so, standard spark plugs are definitely best value. Stick to known brands such as NGK for best results.
    Get new ignition leads and make sure your ignition coil(s) are in top condition. Anything less than optimal will potentially cause a backfire. Remember, a gas engine relies on a strong ignition system.
    If needed, replace the oxygen sensor(s). A properly functioning oxygen sensor can mean the difference between acceptable and unacceptable fuel consumption and performance.
    Make sure the gas system is tuned every year or so (again to minimise the chances of problems). It is good practise to get a gas tune done immediately after an engine service.
    Other than that, enjoy the cheap motoring.
    Regards,
    Dave
    Injected CNG, LNG & LPG: The only way to go better!
    2010 Voodoo Sv6
    Sep 2008
    VY Calais
    Sep 2008
    Feb 2007
    Quote Originally Posted by E.B. View Post
    Whats the economy like on Gas?
    For a VY with Ecotec V6, approximately 16L/100km.
    How would it suit a Supercharged V6?
    You would need an injected gas system for that, but otherwise it will be fine. LPG is less knock-sensitive than petrol (higher octane number) and therefore is highly suitable for boosted applications.
    Regards,
    Dave
    2004 Series 2 VY S Pack V6 3.8Ltr
    Feb 2008
    West Suburbs Victoria
    yee dont get lpg (mixer) on a super charged engine....
    o and btw i remember reading somewhere you'll lose your traction control when your have a mixer system.
    tj
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    booking mine in for SVI tomorrow
  1. Converting V6 to V8
    By tr3nt in forum General Discussion
    Last Post: 19-02-2007, 11:35 PM
  2. converting to gas
    By vtsuperchargedboy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2007, 02:09 PM
  3. Converting My VL to LPG
    By Aussie_Watto in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2006, 09:23 PM
  4. VH Converting 6 to 8
    By smoken-v8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-12-2005, 07:02 PM
  5. Converting my VK to gas
    By Foordy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2005, 09:22 AM
Tags for this Thread
