Results 1 to 12 of 12
Thread: Has any one thought about replace the fuel tank with monaro's??
    VZ CALAIS LS1
    Sep 2008
    Unhappy Has any one thought about replace the fuel tank with monaro's??
    Hi every one
    I just think about replace my vy commodore's fuel tank with the 2006 monaro's fuel tank and that because I wanna had a custom exhaust system with 2 side pipes (like the monaro) cuz I'm totally sick of that one side pipe
    so does the tank gonna fit in my commodore ?
    and if its doesn't ,what can I change to do that and what I need to do that.
    that's all .
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Well, seeing the monaro is a coupe and not a 4 door sedan, you may run into issues.
    VZ CALAIS LS1
    Sep 2008
    yeah but they have almost the same wheelbase, except the monaro has the tank in the middle,am I right ?
    thanx for your reply Mack.
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I wouldn't know about the fuel tank but a twin system on a v6 will drone like crazy.
    A Commodore is a passion. Anything else is just a car
    vy ss commodore 5.7ltr
    Jul 2006
    get a fake tip put on the other side to match, problem solved minimal work required and no one will know bar u if done nicely
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    by memory if you were going to do that you have to raise the fuel filler up heigher and you will have a pipe running in you boot. by memory thats what they did to the monaro
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by cpbait View Post
    untill cold nights come and you have steam comming from one side and not the other
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    It would be possible but then again why bother? The US GTO/Monaro fuel tank was mounted in the boot between the rear wheel arches to comply with US crash laws. There was a massive steel frame that protected it (just in case your car was rear ended at 150mph). From memory the filler was moved but I honestly can't recall for sure.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Reaper
    hmm, maybe so it looks like a supercar filler, or make it higher for lazy obese americans?
    VY s m5 supercharged
    Aug 2008
    Just get your self a fuel cell in the boot, i think you would run into many problems trying to fit a monaro tank
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    you can put a twin system in without changing the tank.
    the system will come from the headers and stay split but side by side, all the way to just after the tank, then one will continue straight the other will go behind the rear bar and out the other side.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    VZ CALAIS LS1
    Sep 2008
    thanx every one for your attention , well i decide to stick with the stock fuel tank cuz I'll spend a lot of money on nothing .
    thanx again
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  2. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
  3. When to replace/clean fuel injectors.
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 01:56 PM
  4. How to replace fuel sender unit!
    By chrishodge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2006, 02:26 PM
  5. Is it possible to replace fuel pump yourself?
    By lippy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 04:15 PM
