Results 1 to 10 of 10
Thread: oh yes power steering shudder help
    vy II equipe
    Sep 2008
    Thumbs down oh yes power steering shudder help
    mines doing it have had the "revised" pipe fitted and its still there
    seen the thread on here about this subject and thought i'd post here and see if there's any new news on this
    can the problem be solved or do i need to Pi#$ it off now?
    one post said a pipe with a bracket ? needs to be fitted!
    any help on this and i'll be forever in your debt.......
    cheers
    shano
    1970 AMC javelin, S2 stagea
    Jun 2008
    so you've got the pipe which goes from the rack to the pump? and runs across the bar behind the bottom of the thermo fans?
    May be air in the power steering fluid, is the fluid level ok? Bubbles in the oil? Is the pump noisy?
    vy II equipe
    Sep 2008
    mate to be truthful i didn't even know what pipe was replaced
    pumps not noisy and fluid is new
    as far as i know the mech bleed the line but just in case how is it done
    oh and thanks for replying
    cheers
    shano
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    mines ****ed as well at it was supposdly fixed by holden as was another 2 ppl i know apparently it just happens again after a while
    Jun 2008
    Default ps
    There isn't any specific way to bleed the system, if its not noisey then it shouldn't need bleeding, if the fluid was pink and had lots of little bubbles in then it'd need doing.
    Here's a pic of where the hose sits behind the fans, the hose then runs under the oil filter towards the rack.
    The hose basically changes the line pressure to the rack to prevent the shuddering when stationary or at slow speeds.
    vy II equipe
    Sep 2008
    after looking @ mine there is no pipe there that you have in your picture
    so only god knows what pipe they replaed then!
    Jun 2008
    They obviously didn't fit a steering shudder hose kit.
    The vy's did have a recall on the power steering cooler hoses as they wouldn't stop leaking due to the crappy clamps the factory used, maybe they did that?
    vy II equipe
    Sep 2008
    all problem fixed new pipe was fitted and now its quiet as
    i found the part No. on the phenix mechanical web site ......
    its real bad when i have to search for things and instruct a mechanic on how to fix it....
    vy II equipe
    Sep 2008
    Soaring Phoenix Mechanical - Home
    list all models ,all known problems and how to fix them....... Enjoy
    Power Steering Shudder (V6) - Some VY's may shudder through the steering wheel during very low speed or
    stationary steering is performed. To help overcome this, a longer high pressure power steering line was introduced. The original line ran directly from the power steering rack to the power steering pump. The new longer line runs from the power steering rack, is routed and secured in front of the engine, and then continues back to the power steering pump.
    High Pressure Power Steering Hose - Holden Part number 92174786
    Mercedes C200K AMG-Sports
    Mar 2007
    Great! I'm gonna give this info to my mechanic when I see him.
  1. VY power steering shudder @ low revs
    By SUPERV6 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2011, 11:39 PM
  2. power steering shudder
    By Berlinarator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2006, 11:07 PM
  3. power steering low speed shudder
    By jon_d2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2006, 05:27 PM
  4. Power Steering shudder on V8??
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-03-2006, 12:30 PM
  5. power steering shudder
    By JoshTaylor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 04:53 PM
