Results 1 to 15 of 15
Thread: Th Door won't unlock
    VY Executive S2
    Aug 2008
    southeast queensland
    Default Th Door won't unlock
    Well the drivers side back door won't unlock. The keys seem to be unlocking the other 3 doors but not that one. Can't even manually open it.
    Child loc is also on aswell.
    Is there anyway to get into that side?
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    yopur going to have to pull the trim off and have a look around. Sounds like the deadlock is stuck on
    no longer a hoon by association - the commodore is gone
    VY Executive S2
    Aug 2008
    1970 AMC javelin, S2 stagea
    Jun 2008
    VY Executive S2
    Aug 2008
    Well I locked the car and left it for a few hours and well it worked.
    For the past 2.5wks when you lock the car it beeps at you, I thought maybe we were holding a finger on the button for too long, but nope.
    Maybe the beep is letting us know something is wrong with the lock? as it doesn't do it all the time?
    Jun 2008
    the beep is indicating that one of the doors isn't locked, common problem on vy to vz with lock actuators jamming.
    From memory they're around $130 mark, but don't hold me to it.
    VY Executive S2
    Aug 2008
    Thankyou for the info. So, who do I get to look at it though?
    Would it be an auto electrician?
    VY Acclaim
    Aug 2006
    Hmmm... mine is doin kinda the same thing... very annoying when I can't unlock the passenger doors and stuff so other ppl can get in...
    Except this is an intermittent problem for me... sometimes it works fine, sometimes it doesn't...
    VY Executive S2
    Aug 2008
    Jun 2008
    they jam up due to dust and dirt getting into the door and jamming up the actuator, there is a plastic weather cover behind the door trim but it doesn't protect the parts inside the door.
    I fitted one today, quoted 200 including part and labour.
    Takes about 20 to 30min if you know what you're doing.
    Very common problem so don't think your car is the only one play up.
    Have fitted over a 100 of these door lock actuator assembley's, used to do heaps when vy's were under warranty.
    VY Executive S2
    Aug 2008
    hmmm thanks for that. so who do I get to fix it? I don't like the holden dealers around here as they just rip you off and stuff up your car.
    Jun 2008
    Not sure who could take it to up your way, any workshop could fix it.
    Get some quotes and see how you go.
    VY Executive S2
    Aug 2008
    VY II S
    Sep 2008
    The rear drivers side door has stopped lock/unlocking via the central locking as well. I have removed the door trim except for disconnecting the wire from the electric window switch. Is there a trick to doing this or are they just tight to unplug ?
  15. #15
    monaro cv8
    Mar 2010
    Default cant unlock passenger door cv8 monaro
    Hi i have a monaro , yeah i know not really a commodore but someone may no cause theres a lot of head scratching going on , and to make it worse its the british version so guess where i am and theres not many dealers that know about them
    anyway the problem is that the passenger side door will not unlock tried various different things for hours and still no luck but it had been playing up and not locking properly and now the opposite , so now cant get door open to have a look at actuator as from what i have read seems to be the problem .....any ideas anyone /////////////////////////////////
    kev
  1. Passenger Door Deadlocked - Won't unlock!
    By Garrett10_4 in forum Electrical Wiring / Questions
    Last Post: 22-10-2008, 12:52 AM
  2. Passenger Side Door wont UNLOCK
    By hsvpunk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2008, 10:36 AM
  3. Front door wont unlock please help asap
    By stumps5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 09:35 PM
  4. Other Doors Unlock When Drivers Door is Opened
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 09:55 AM
  5. VX all unlock
    By asustek in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2004, 05:04 PM
