Results 1 to 6 of 6
Thread: vy ss
    VY SS A4
    May 2007
    sydney
    Question vy ss
    hey there ppls, ive just bought a VY SS, and ive noticed a split in a hose, the hose comes out of the intake manifold, just behind the throttle body, then the hose runs around the drivers side of the engine to the back of the motor. It also has an earth wire from it to the head. Can anyone tell me what this hose is called, and what does it do?, the car still runs great. many thanx
    cheers Shano
    The Earth has music...if you take the time to listen
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    oil breather tube from rocker cover, its there for emissions, oil vapor/fumes go into the TB intake and gets consumed during combustion.
    oh and the wire going to the head, is probably just the earthing lead which runs down along the injectors giving them earth? maybe
    VY SS A4
    May 2007
    sydney
    Default cheers
    Quote Originally Posted by Farlig View Post
    thanx for that, theres air passing through it, when i covered the hole, the idle went down, must investigate more as i was fiddling around with it, and now its broken all the way through
    Farlig's Avatar
    Y-Series Clubsport
    Jan 2005
    Quote Originally Posted by shano8 View Post
    if you replace, put in a oil catch can might aswell hehe
    1970 AMC javelin, S2 stagea
    Jun 2008
    The PCV hose usually split at the throttle body or at the Y connection at the back of the intake.
    Replacing the hose is pretty simple, or if its only split at the throttle body you can cut off the split hose and fit a piece hose about 1inch long of better quality, if its not fixed it can put the check engine light on and cause the engine to run lean as its sucking in more air than it should throwing out the fuel/air mixture.
    VY SS A4
    May 2007
    sydney
    Quote Originally Posted by jav360 View Post
    cheers, i fixed the problem, all good now
