Results 1 to 7 of 7
Thread: 3 windor dash conversion and speedo tricks
    VY SS
    Aug 2004
    SE Victoria
    Default 3 windor dash conversion and speedo tricks
    Hi All,
    Just a quick couple of questions:
    -Can I put a 3 window dash, from say a CV8, into a VY SS? I assume the fuel sender might need to be replaced as mine is a S2 car and the dash might be S1. What else needs to be done? What happens if the dash has less KM on it than the car does?
    -What are the speedo tricks for VYs? Say the VZ digital speedo, etc...
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the sender change may not be needed, the dash can be programmed to suit the reverse sender if needed, if you go ahead with the swap i can show you how to determine which sender you have.
    the digital speedo can be activated yes, this needs to be programmed into the cluster.
    the odo can be altered but it needs specialist programming.
    basically it can all be setup to suit your car quite easily.
    Rob
    VY SS
    Aug 2004
    SE Victoria
    I love you Dr Bob! in a manly way of course.
    So, where is vic would I be able to get the programing done?
    Also, lets just say i put the dash in and need to drive to work for a week o\r 2, the car will still be ok in the interium?
    Doctor Bob's Avatar
    May 2004
    where are you located, if its too close to dromana ill start getting scared...
    i can do it if you want to bring it this way.
    its best not to put it in as if the srs (airbag) configuration is different it will log a code in the srs module.
    i can program it on the bench so it will all work correctly.
    pm me for details
    Rob
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    I'm about to undergo this mod, too using a hsv s2 dash. if i put it in and it logs a code into the srs module, what does that mean?
    secondly what info do the 2nd and 3rd auxillary lcds display?
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    Doctor Bob's Avatar
    May 2004
    it means the airbag system wont work & the dash needs to be configured to suit the car
    trip computer info mainly
    sp001in's Avatar
    MALOO R6
    Jul 2005
    QLD
    Quote Originally Posted by Doctor Bob View Post
    where abouts can I go in Brisbane area, to have this dash installed, and calibrated correctly. Holden said they can put the K's onto it for me, but mentioned nothing about SRS code logging. this concerns me greatly because my fiance drives the ute too. I want it to be safe.
    below, old and new dash.
    Attached Thumbnails Attached Thumbnails 3 windor dash conversion and speedo tricks-ba21_1.jpg   3 windor dash conversion and speedo tricks-dsc00983.jpg
  1. VR Manual Conversion - How to Get you speedo working again using the auto harness
    By mal62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 03:35 PM
  2. Need some help!!!! abt speedo sensor on Vr (auto to manual conversion)
    By holdenrocks in forum Electrical Wiring / Questions
    Last Post: 29-03-2008, 08:20 AM
  3. Speedo conversion
    By AGRO-V8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2007, 05:26 AM
  4. Question Regarding Manual Conversion Speedo wiring
    By Dub Alley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:39 PM
  5. Electrical Speedo Conversion
    By ggold in forum Electrical Wiring / Questions
    Last Post: 24-04-2005, 12:37 AM
