What do i need to change if i want to take out my supercharged V6 motor and put in a naturally aspirated ecotec V6. I have heard the boxes are different. The supercharged motor is no good and i dont want to keep throwing money at it to try and fix it.![]()
sell your car and buy another one... dont waist your money by doing an engine conversion
im afraid its not really an option, the car doesn't run and i owe to much on it. How much do you think i could get for a May 03 S pac in this condition.
whats wrong with the engine?
I over heated it and cracked the heads. I have recbuilt the top end with new heads and all new gaskets. I got it runing but when i took it out it stalled at 120Km/h and i cant get it running at all now. I done the rebuild with a mechanic thats a mate of mine so it was done right. It looks like some more damage was done other than the heads.
There's nothing wrong with the supercharged v6 in the VY, it must be the work....no offense. They have a few components that require specialist knowledge.
One thing that is an idiosynchrasy of them is when they do go bad, a simple thing can seem like a big problem.
Where are you located? Hate to see you chuck away a perfectly good engine (if it's still good).
Baldivas, 30 mins south of Perth, WA
There are a few boys that have good knowledge of the L67 over there, OZ38 and Astro (forum names), I'd contact them at least b4 you throw out your engine and even if it's shagged Astro can help you with converting to an Ecotec, he has done plenty but usually the other way around.
Have you checked out www.l67torque.com • Index page ? They are on that forum and also there is alot of good info that may help you out.
I have just converted to a supercharged motor all you need is complete harness computer and gearbox and access to tech 2 efi tool
the box is identical, its the t/c that is different (different stall rpm)
what colour is the care is the body in good nick im looking to buy vy , there are two wreckers in porth that do drive in drive out engine swaps for 1000 bux for the vs-vy ecotec , your vy has a memcal type computer just pay 1000 get motor put in and all wired then just change chip over or they will do u an supercharge swap for aroudn 2500 i think
