Results 1 to 14 of 14
Thread: handbrake won't lock in??
    tommo_49's Avatar
    tommo_49 is offline toMmyV :P
    VY Executive S2
    Jul 2008
    Default handbrake won't lock in??
    The other day i pulled up my handbrake and it just went back down again and didn't lock in. At first i thought the cable had snapped, but the handbrake still works... you just have to hold it up... lol. I think it has something to do with the cogs not locking in however i'm not really sure. Any advice would be greatly appreciated. If i have to go to holden to get it fixed how much will it cost?
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    easy fix, they have a locking pin that engages to keep the handbrake up.
    pull the boot of the handbrake and inspect for damage. you may even find it has come loose and fallen off. otherwise order a new locking pin from holden, about $7.00
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Guys I know I'm digging up an old thread here but didn't want to start a new one and this was all I could find...
    Long story short I came home from work just then and tried to apply the handbrake but it won't lock in and you can't hear any "clicks" when you pull it up... It still works when you pull it up i.e. brakes the car, however, won't hold in position so it's pointless unless of course I wanted to turn my car into something out of Tokyo Drift :S
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Did you read the other replys to the thread before you dug it up?
    OP was having the same issue as you, and it was diagnosed as a possible locking pin failure and instructions on how to check it were given.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Cheers CHAMP!!! I was searching for more detail that's all and to see if anyone else had more recently come across this problem!
    Solved it myself anyways, had to get the whole handbrake assembly as "apparently" you can't just get this so called locking pin on it's own... I'll be posting a picture of the problem shortly in this thread so that it will be more detailed for anyone else looking for this problem so that they can resist the urge to post on this thread, in turn making you resist the urge to reiterate what has already been replied previously!
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Quote Originally Posted by jr689 View Post
    Please do, mine just ####ed up lol. What's the price on it?
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    I'll take a picture for you tomorrow arvo after work haha! Umm it was about $64 I'm pretty sure, which I guess ain't too bad considering it's the whole handbrake assembly and what not :S
    To get it off you will first need to undo the handbrake cable adjuster nut, then undo the two bolts that secure the handbrake assembly, and then pull the relay upwards so it disconnects from the handbrake assembly... Once that's all done you'll be able to pull the handbrake assembly out of the car, it's pretty straight forward really.
    When you go to get the part see if they can give you just the individual part instead of the whole assembly cause I want to see if I got ripped off hahaha but I doubt it :P
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Orrrrrr if your not in too much of a rush to get it fixed you could go to a wreckers and try your luck, but I guess for 60 odd dollars you may as well get a newbie in my opinion... Food for thought nonetheless!
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Ok so I said that I'd post a few pictures just to help anyone else searching for this problem so here goes...
    Attached Thumbnails Attached Thumbnails handbrake won't lock in??-1.jpg   handbrake won't lock in??-2.jpg   handbrake won't lock in??-3.jpg
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    The second picture shows the "locking pin" situated where it's supposed to be, clipped into the metal arm.
    Basically the plastic "locking pin" wears out from movement within the metal arm and eventually slips out and can no longer stay in place.
    Apparently from what I was told, you can't just buy a replacement "locking pin"... You have to buy the whole assembly (first picture) which for my car was $64... Not too bad a price but then again it's not great.
    Oct 2009
    S.E VIC
    Did you go to holden or Repco or something
    edit: I'm guessing you gotta take out your hole centre console?
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Went to Holden mate, and nah just have to pull off the rubber boot (pull toward front of the car and it'll eventually come off... has some sort of clue fixing it to the assembly) and then push your seat all the way back and there are two bolts fixing the handbrake assembly to the car... It will all make sense once you take off the rubber boot though ay!
    Oct 2009
    S.E VIC
    Thank god, i thought i had to take the damn console off. Rubber boot i've noticed you can move but it looks like it'll take a bit to get off hahaha
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    Yea it took a fair bit of force to slide it off the lever to say the least haha... Just hold it as if you were going to pull the handbrake up, but use to hands and pull towards the front of the car and give it a bit of a wriggle as well to loosen up whatever holden used as glue in there haha! But after that it's super easy and straight forward, which was a fresh change for me anyways ha!
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. Handbrake
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-01-2009, 10:33 AM
  3. No chirp with remote lock.. what's dead lock?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 04:06 AM
  4. Is it possible to bypass the handbrake lock on dvd players?
    By fluxwildlyuncut in forum Car Audio
    Last Post: 20-08-2008, 02:37 PM
  5. vb-vc handbrake
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2006, 08:55 AM
