Results 1 to 13 of 13
Thread: Water in boot Lid
    G4orce's Avatar
    G4orce is offline HSV Owner
    Vy Senator Signature 5.7lt auto
    Aug 2004
    Melbourne SE Subs
    Default Water in boot Lid
    Hey guys I have a real annoying problem with water getting into boot lid and whenever i open my boot I get water all over my boot install (currently working on, Thread to come)
    Does any one know how this could be fixed? It is a Vy Senator so it has a rear factory spoiler. Could the spoiler be causing this problem? or is there another known problem
    My Beast VY Senator Signature 5.7lt Auto
    More info Click on like below
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    nah dude not the spoiler i have the same problem..... its so annoying any help would be good
    G4orce's Avatar
    Aug 2004
    Melbourne SE Subs
    Quote Originally Posted by rippen50 View Post
    I guess in a way I am happy i am not the only person with the problem. I guess looking at the good side it works as good sound deadening and stops boot rattle lol.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    im guessing maybe the rego plate seal no sealing correctly, are you able to get in the boot with a light or two while having someone hose the car?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ Commodore SV6
    Dec 2007
    Auckland, NZ
    Default Anyone had luck?
    I have the same problem. Since we have been having a bit of rain here recently water seems to be pool inside the boot lid (comes out of the little holes on the left and right side lip!!) Pain in the bum and possible cause for rust in the future.
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    do you guys mean its comming out of holes or the way it happens in the vts where when u open the boot the water flows along the boot and in to the bootspace
    VY monaro
    Nov 2008
    Wheelers Hill
    ur seals between the spoiler and boot are buggered, one easy and quick way that might fix it is to remove the spoiler and put rubber bushers on, I remember when i was taking mine off the was this black silicone sort of stuff around the screw which was a pain to get off, but im pretty sure that black stuff stopped water from coming in. My spoiler didnt come out of factory, the previous owner got it put on.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    haha, I had a VR with the same problem, but as it wasn't an expensive car I decided to drill holes in the bottom of the boot lid to drain the water.
    commsirac is offline Banned
    vx
    Aug 2007
    i have the same problem on my vx berlina where the complete tail light plastic thing seems to trap the water. Ive taken it off and all the seals seem fine, its just a bad design, will be drilling holes in the bottom too.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Nissan Pathfinder
    Sep 2005
    I have this problem, looks to me as if its going in through my spoiler where the wiring goes to the LED brake light. There isnt any washer around the hole (well not on mine). I have just picked up a rubber washer and put it there. Hopefully will stop the leak, will wait and see I guess.
    lastlegend's Avatar
    lastlegend is offline Phantom VY SS
    2003 Black VY SS + 1999 Silver VT Olympic Sedan
    Sep 2008
    Thorneside QLD
    Default Yep...common issue
    I have a VY SS and the same thing happened, I checked all the seals and could not find where it was coming from so I just drilled a series of holes along the bottom edge and rust treated the fresh metal and spot painted the holes....problem fixed.
    VZ Commodore SV6
    Dec 2007
    Auckland, NZ
    Default Fixed mine!
    Had a bit of spare time on Monday and decided to take the spoiler off. The "gaskets" were pretty much stuffed. All I had to do was replace the foam under the spoiler (each side), scored this from Mitre 10 Mega for $11NZD and RTV'd around the holes for extra protection. Re-assembled everything and gave the car a hose off later on in the arvo no leeks. Further to this, being a S model commodore, I also too off the black surroundings around the number plate and RTV's the screw holes. Hopefully everyone else has a bit of luck fixing it.
  1. Water in Boot
    By Rodeo058 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 09:11 PM
  2. water in boot
    By dale s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 01:21 AM
  3. Water in VS boot lid.
    By SunCoastSister in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 02:06 PM
  4. Water in Boot Lid
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2005, 12:29 AM
  5. VS - Water in boot lid.
    By pod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2004, 09:48 AM
