Results 1 to 12 of 12
Thread: Fitting a tow bar to a VY S2 Sedan
    Barrie's Avatar
    Barrie is offline VY II Police Pack
    VY II Executive [Police Pack]
    Oct 2008
    Default Fitting a tow bar to a VY S2 Sedan
    Hey there guys, I'm looking at fitting a tow bar to my VY, has anyone done this themselves or does the job really have to be done my the experts? There are a few floating around second hand at a good price so I was tempted to do it myself rather than having the tow bar company charge me to fit one.
    Finally, if anyone has photos or instructions that'd be cool.
    Thanks again & play safe
    Barrie
    1*
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    G,day mate,
    its pretty easy, just dont rush things, these are the steps i used.
    -Remove all screws from rear bumper
    -2x screws on mudflaps per side,
    -1x screw below mudflap per side,
    -2x plastic screws underneath rear bumper
    -4x plastic screws on top of rear bumper
    -4x 10mm nuts on inside of bumper, note: will need to remove l/h andr/h side interior boot trims.
    -unclip bumper and remove.
    -remove the reinforcing bar and its brakets (17mm x 19mm bolts)
    (Now im not sure if you have to reinstall the reo bar over the towbar, some one may have to enlighten me on that)
    -install the towbar using the original bolts of the reo bar.
    -put your bumper back on (remember to take the little square plastic out for the tounge).
    Its not hard, i did this by my self
    Good luck
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    Quote Originally Posted by 01VY2NV View Post
    Yes the Reo Bar does go back over the installed towbar. it can help avoid damage to the towbar if you get rear ended
    Aug 2008
    Quote Originally Posted by batemada View Post
    Cheers mate
    Barrie's Avatar
    Oct 2008
    Thanks guys, sounds like I'll go that way, the stores that sell them charge a bit for them. Does anyone know if there is an easy spot in the wiring loom to tap into for the plug?
    Thanks guys play safe
    Barrie
    1*
    Oct 2005
    If you get the factoy wiring for it, it will piggyback onto your existing wiring. takes all of about 30 seconds to hook it up.
    davo43's Avatar
    davo43 is offline Another google mechanic
    VZ Executive Wagon
    Oct 2008
    Launceston, TAS
    Does anyone know if this procedure is the same for a VZ wagon?? If not, how does it differ?? Cheers!
    Stock Odyssey 2004 VZ Executive Wagon
    My Intro Thread
    Oct 2005
    Quote Originally Posted by davo43 View Post
    Pretty much the same except it is a bit harder to remove the bumper at least thats what i found on my old VT wagon. The wiring harness plugs in behind the drivers side rear light.
    VYII Wagon Dual Fuel HBD
    Jun 2005
    Davo, in a wagon it will also depend on the towbar rating...a 1200 or 1600 kg bar are similar, but a 2100 kg Hayman Reese bar for example also has a pair of strengtheners which sit inside the spare wheel tub and bolt to the bar thru the rear panel. I have recently fitted one to my dual fuel VY II and it required some small modifications to fit, including the temporary removal of the LPG tank. It is not impossible for the home mechanic to perform. Best of Luck.
    davo43's Avatar
    VZ Executive Wagon
    Oct 2008
    Launceston, TAS
    I completed the removal of my existing GM towbar on the weekend - took me about 2-3 hours but a lot of that time was either individually cleaning every part I took off or standing back trying to work out what to do next... The primary difference with the wagon that I found was the rear bar has no bolts (it simply unclips once you have undone all the screws) so you only need to remove part of the RH interior trim to unplug the harness and reconnect the tail-light (reverse if you are fitting a towbar)... Don't do what I did and forget to reconnect the tail-light - was pretty scary when I hit city traffic and realised my RR indicator was a no-go... The tow harness is connected in series so removing it creates a break in the system...
    Thanks guys for all your advice
    My Intro Thread
    Oct 2005
    Also make sure that you get the correct wireing harness for your car, if it has parking sensors you need a differnt wiring harness to a commodore with no sensors.
    VZ EQUIPE
    Oct 2008
    where did you find second hand tow bars for VY - VZ sedan's
  1. Fitting a TOW BAR
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-04-2008, 09:00 PM
  2. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  3. Fitting LPG
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-03-2006, 06:47 AM
  4. Fitting a Tow Bar to VX sedan
    By Millo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2005, 10:56 PM
  5. Fitting ABS
    By HQ_Kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2005, 10:46 AM
