Results 1 to 9 of 9
Thread: taking a long time to start up
    VY commodore 'S' Ute
    Sep 2008
    Default taking a long time to start up
    I have a vy s ute and whenever i start it up after starting within a few hours before, it takes a long time to get going
    it sounds like its starting but wont turn on for a few seconds and am unsure why
    help please
    also brakes are sqeaky... recommend new brake pads???
    cheers
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Maybe you battery is dying or possibly your alternator? If it sounds like it is turning over properly just not firing, it could be either an electrical fault or a fuel supply fault. I would just stick a voltmeter over the battery while running to check if it's ok. It should read about 13.7. Good luck with it.
    I would recommend Bendix CT brake pads. Very good for the money.
    A Commodore is a passion. Anything else is just a car
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    that won't give a correct indication of the battery status. I've had a car measuring 12.6 turned off and 14.2 running, and the battery still was dead. new battery and it starts like a dream.
    I have also had this problem with my vy. sometimes would start straight away sometimes, would crank but not start. just put a new battery in and it has been perfect ever since. spend the money mate, go to battery world get a battery warranty too. or call marshall batteries they'll come to you. unless your car is blowing smoke this is really the only reason.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    '04 VY II Executive
    Mar 2008
    Adelaide, SA
    i had the exact same problem as this aswell, it got to the stage that it never started (crank but no fire). RAA said it might be the inhibitor switch, so i took it to my holden dealer (where i bought the car from) and three days later it ended up that my keys needed to be re-programed with the BCM, ever since that it has worked fine.
    vy s commodre ute
    Nov 2008
    hey guys i have a similar problem with my vy commodre ute. turn the key and its clicks over sometimes 2-4 times befor it fires once started it runs fine, can smell plenty of fuel coming out. and thoughts? starter motor, battery, please need help
    Nov 2007
    my vy ss is doing the same thing it cranks over trun the key back to off crank it and it starts
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    getting a new battery in my car solved sooo many issues, mainly with stereo. odd noises here and there, new battery must earth the car better.
    vy s commodre ute
    Nov 2008
    still not 100% sure what is wrong with it. need it fixed soon starting to anoy me a lot. ill try new battery tomorrow
  1. Restoring the brakes(after long time without use)
    By shanhsv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2008, 10:12 AM
  2. Hi everyone, long time no see.. you'll never believe it..
    By SeanV8 in forum VN - VP - VG - VQ
    Last Post: 11-12-2007, 10:09 AM
  3. VX leaking oil onto exhaust manifolds after not being started for a long time
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 09:54 PM
  4. Vt Won't Start After Taking Battery Out
    By revvy67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2006, 11:27 PM
