Results 1 to 7 of 7
Thread: removed passanger seat and.....
    VY Executive
    Aug 2008
    Default removed passanger seat and.....
    i removed my passanger seat so i could mount an amp... i have put the seat back in and now im left with an error message saying "SRS AIRBAG FAULT"
    can this be fixed easily or do i need to go to holden and have them rip me off???
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    make sure the connection under the seat is plugged in.
    If you forgot to plug it in and turned the reds on then you have a problem and may have to take it to holden for a reset
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    did you disconnect the battery when you took the seat out???
    other then that you might need to go to holden to clear it...and it might cost ya
    VY Executive
    Aug 2008
    no i didnt take the battery out just unplugged it. a mate of mine was charged $150 just to get a reset for his engine light
    Marks-VY's Avatar
    Marks-VY is offline I love cars
    VT2 Berlina
    Apr 2005
    $150 is crazy. I was quoted $50 but the technician did it in the car park and told me to just forget about it....
    Thanks Suttons
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by eclipz View Post
    As you have had the ignition on with the seat out the SRS module has logged a code.
    The only way is to take it to a dealer & get it cleared.
    you will probably do much better getting it cheaper or free if you loose the attitude about getting ripped off.
    basically you have done something to the car without actually knowing what you were playing with, The dealer has a very expensive scan tool they can use to fix your issue, they also need to provide someone trained to use the tool .
    So basically its your fault... deal with it.
    VY Executive
    Aug 2008
    all good. was quoted $45 by local dealer
  1. VX II Passanger Airbag Installation
    By Cica9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2010, 05:04 PM
  2. WTB - vx vy vz black door trims both on passanger side
    By lumina01 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-09-2008, 02:44 PM
  3. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  4. Left passanger chair wobbles!!
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 04:09 PM
  5. Coax Cable under passanger seat,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2005, 06:04 PM
