Results 1 to 4 of 4
Thread: arial probs
    04 vy s ute
    Oct 2008
    south west sydney
    Question arial probs
    i had recently bought a vy s pack ute and had noticed the arial only goes a 3rd of the way up.
    is there any way of making go the full height by adjustment or do i have to replace the arial all together??
    thanks
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Get someone to stand by the aerial and try gently pulling it up as you turn the ignition on. Sometimes, the sections of the aerial get an accumulation of dirt/grease/surface contamination which prevents them from extending fully. If the resistance to extending is too great, the clutch in the antenna gearbox will "slip" until it reaches the cut off point and the antenna ceases trying to extend. You might also have one section damaged which has jammed within the next section down. The mate pulling on the antenna might be all it takes to help it fully extend, but don't try to lift the antenna too hard.
    It is important that you try this only when turning on the ignition with the radio turned on, as you shouldn't be able to pull the antenna up manually.
    04 vy s ute
    Oct 2008
    south west sydney
    VY Executive S2
    Apr 2008
    Default Vy series ii antenna
    Hi Guys, wondering if anyone can help me. When i turn of my car the antenna comes down sometimes half way sometimes all the way then goes back up and radio turns on. Its a pain in the asse because i sometimes lock my car and go only to find my radio on when i return. Do i need a new antenna. Has anyone experienced this problem.
  1. Arial
    By HoldrodeoLT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2008, 08:37 PM
  2. VP Arial? Stays up?
    By benjiaka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2007, 01:36 PM
  3. Arial Replacement
    By jabbavx in forum Car Audio
    Last Post: 24-02-2006, 02:39 PM
  4. install an arial
    By Duck_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 10:59 AM
  5. VQ arial
    By yotaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 04:29 PM
