hi guys
your opinion matters ,,
Can bad tires cause a wheel bearing problem?
Or it’s caused by rough driving (rally).
Is it worth buying a non genuine part (wheel bearing, shoes, brake pads, bush, ball joint, ......
thanks for passing by and sharing ideas..
A constantly bad allignment for years and years may wear a bearing prematurely but it's unlikely. If it's the front left bearing that may be a sign of hard cornering, roundabouts and hard right hooks are more common than lefties I think.
What are the symptoms? I assume we are talking commy here, just noticed you refer to rough driving/ rally.
i do drive hard sometimes,
..the symptoms are wheel bearing noise ( more in front wheels) and wheel play at hard cornering ,,
...Is it worth buying a non genuine part (wheel bearing) ???
am gona replace all wheel bearing this week, realign them ,, hope this helps
umm i know trailers are diff but i used to work with trailers and **** like the wheel bearings umm u deff need good quality for them (these were hire ones home ones not so much) and in a car i would think it would be even more stress so i wouldnt spare a cent not on the bearings dunno if this helped at all
