Results 1 to 6 of 6
Thread: Interior light upgrade
    Marks-VY's Avatar
    Marks-VY is offline I love cars
    VT2 Berlina
    Apr 2005
    Exclamation Interior light upgrade
    Hi,
    Anyone know for sure if the series 2 interior light/sunglasses holder that sits between the sun visors, screw straight into the series 1?
    I assume there is no change to the roof lining/steel roof structure although I want to be sure before hacking into my roof lining.
    Also, is the wiring loom there or does it need to be run from the centre light switch?
    Thanks.
    Marks-VY's Avatar
    VT2 Berlina
    Apr 2005
    Thumbs up
    I can answer my own question now! The roof structure (reinforcing rib) is already set up to accept the front interior light/sunglass holder, as seen on ebay. Check a car with one already installed to get the alignment, then mark the roof lining using a template made from the unit. A very sharp hobby knife will cut through the VY roof lining leaving a clean edge. There is some cotton wool underlay which I cut out to match the hole in the roof lining.
    Running wires from the centre light assembly was wasy (I used a piece of stiff guide wire and ran it over the top of the cotton underlay, then pulling the wires through behind it).
    Depending on how technical you want to get, you only need two or three wires from the centre light, even though the plug on the new unit has more.
    I only used the permanent live and permanent earth, so as to enable me to manually switch on the lights either individually or together, although you can also pick up the switchable EARTH, if you want the front lights to operate with the doors. I wanted to avoid this to prevent additional drain on the battery with doors left open.
    The bonus now is that I can turn the centre light off when the kids are asleep in the back, and the front lights gives HEAPS of directional lighting without waking the kids.
    If anyone is interested I can give provide a list of wire colours to get it working (note that the wire colours for the centre assembly bears no resemblance to the front assembly) as well as some photos.
    Regards,
    Mark.
    VX Executive
    Jul 2005
    Nelson, New Zealand
    Some pics of your wiring job would be good. Im trying to do something similar but not sure which wires to splice of as I want my extra lights to come on when ever the interior light comes on especialy when I unlock the car as the lights im putting in are under the external door handles.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    thats an interesting one ho7den. ill be interested to see the finished product....
    Jim_Bob Guest
    VX Executive
    Jul 2005
    Nelson, New Zealand
    For those of you interested in how the door handle lights went check out this new thread Blue LED,s under door handles . The job is done and was succesfull but will have to wait untill it gets dark to show the desired affect.
  1. interior lighting upgrade
    By AKII1R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 05:17 PM
  2. Interior Upgrade ?
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2007, 10:37 AM
  3. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  4. Light Upgrade
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2006, 12:34 PM
  5. Upgrade VL Interior. Idea's
    By SuperStar in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2004, 03:19 PM
