Results 1 to 14 of 14
Thread: what is it??
    vy ss series2 ute
    Sep 2008
    Default what is it??
    on the intake pipe to the throttle body, i found a wire disconnected from what must be a sensor, looks a bit like a led light in a plastic housing that sits in a hole in the underside of the intake pipe what is it?, what does it do? and should it be connected?
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    I can't be sure, but do the V8s have a WOT (Wide Open Throttle) sensor something along these lines? Just speculation on my part....
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Hmmm, a pic would be helpful.
    I too am speculating, but it sounds MAF related to me. Is your car MAFless tuned? If so, that explains why it's disconnected...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    Quote Originally Posted by vyss300kwute View Post
    sounds like the IAT mate, intake air temp sensor.
    VT
    Apr 2005
    QLD
    Farlig is on the money, mate. There is usually a 'C' clip that holds them in on the inside, hopefully, it's not stuck to the back of one of your intake valves lol
    vy ss series2 ute
    Sep 2008
    yes it is mafless tuned, ill try to get a pick of it over the weekend i too thought it was a air intake air temp sensor, if it is that should it be connected and if it isn't could it possibly cause damage or loss of power?
    thanks for the replies guys..
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    lmao, that is your IAT Sensor. Best you plug it in!!!
    It should run bloody brilliantly when its cold...not so healthy when its hot.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VT
    Apr 2005
    QLD
    Just trying to make heads or tails out of the first post, the sensor is still in the pipe and electrically disconnected? or the sensor has fallen out of the pipe? if the latter is the case, then you have been sucking dirt in to your engine.
    minux's Avatar
    Feb 2005
    I'd say he pulled the IAT out to look at it. I read it as the wire was disconnected at the clip.
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Ih he says it looks like a littred LED, then my bet is the whole IAT sensor has come out. Just push it back into the whole in your maf pipe.
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    car will run rich as **** without it plugged in.
    If you buy those 20hp + kits off the net, the send you a resistor which you loop into the harness and not plug into the IAT sensor. tells the car it's cold like in the morning and makes it run a bit punchier. NOT good for long term use, as you'll stuff mixture sensors.
    plug it back in, it's there for a reason.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    VT
    Apr 2005
    QLD
    Quote Originally Posted by sp001in View Post
    (Edit: This post only applies if the sensor is plugged in electrically, but is not in the tube :P)
    How? What's the temperature difference between inside and outside the tube? If you were talking dry bulb and wet bulb, there would be a difference simply because of the airflow, but i don't think the sensor picks that up. I'm not being smart, but tell me how it can sense the difference?
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    If the sensor is out of the intake it will actually run lean until the o2 sensors trim the mix. The air in the engine bay will be hotter than that in the intake. The pcm will calculate a less dense volume of air due to the high IAT so will inject less fuel.
    If unplugged the intake temp will be measured at a default -40 degC & will run rich.
    vy ss series2 ute
    Sep 2008
    ok so it is air temp sensor, and ill plug it in today..
    i did notice the car is running rich though it always does, but i done some serious highway driving on the weekend and best fuel consumption was 11L/100km, which is crap from memory i usually get around 9L/100km..
    it was in the pipe but unplugged, how long it has been in this state im not sure..
    thanks for the help guys and gals..
