Results 1 to 7 of 7
Thread: VY Steering Wheel Buttons
    2003 Commodore VY S2 Executive
    Nov 2008
    Default VY Steering Wheel Buttons
    A have recently bought a 2003 VY series 2 executive and i am having problems with the buttons on the steering wheel. Volume up mutes and volume down actually turns the volume up. Any ideas on how this is fixed?
    MEANVY's Avatar
    MEANVY is offline Donating Member
    VY Omega
    Aug 2008
    Darwin, NT
    sounds like a couple of mixed up wires, if mute turns it down...
    take the wheel out and unscrew the back, you should be able to see where the wires are coming to and going from. if your not up to it you might take it to a cheapy place, like autobarn or something, or you could bring it up at your next service?
    There's plenty of room for all of God's creatures...right next to the potatos
    Mitch's Ex-police VY Commo
    Quote Originally Posted by VT SERIES II View Post
    if a stripper said it , it MUST be true!!!!
    .....I still think its dirty .....
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Quote Originally Posted by MEANVY View Post
    No it has nothing to do with wiring. Mine does it as well occasionally. I believe it is a BCM issue. Pretty common fault.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    its well documented in the VY faults thread guys.
    i had this issue with my old vy acclaim, 1/10 times it was dickie, i just lightly taped the side of them and it fixed it :S on the clubby i have never had this issue *touch wood*
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    VY2 Berlina
    Jun 2008
    Castle Hill
    mines USED to do that. I've had it fixed. THey use a voltage divider system, and theres a shorting somewhere, causing incorrect signals to be sent. When phreddy did my lights and stereo, he kindly just resoldered the connections on the remote.
    Its not a hard thing to do yourself, i find it fairly easy if your careful(but im an electrician)
    IN the >3 months since its been fixed, its only gone spazo 1 or 2 times
    Nov 2008
    the problem is only happening some times about 80% of the time, the rest of the time it works fine. i pulled apart the steering wheel on the weekend and the circuit board all looked fine, solders were in good condition and there were no other problems with it.
LinkBacks (?)
  1. Steering Wheel Stereo Buttons
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2009, 07:30 PM
  2. steering wheel buttons
    By Archers in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-06-2008, 08:28 AM
  3. Buttons on steering wheel
    By AlpineRaven in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2008, 06:16 AM
  4. Steering wheel buttons.
    By Lloyd1986 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 01:52 PM
  5. vx steering wheel buttons
    By beamer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2006, 09:34 AM
