Results 1 to 7 of 7
Thread: Broken wheel studs help
    VY Commodore
    Nov 2008
    Default Broken wheel studs help
    On the weekend my wife had a flat tyre, someone stopped to help her & snapped 2 wheel studs, any advice on this as to do I need to replace the whole hub or if the studs will come out once I remove the hub. Also is it difficult to remove the hub, I have only ever done it on older cars with no ABS.
    VR V6 Manual
    Aug 2008
    Central Coast, N.S.W
    you can buy studs for like 5 dollars. preety sure they screw in from the back of the hub
    SAV_117's Avatar
    SAV_117 is offline Donating Member
    VY Lumina
    Jul 2008
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Just hit it from the wheel side with a hammer sharply and they will punch thru. They have splines on the back and a pan head which press fit into the hub. Buy a couple from Holden (will cost around $5) and put them in from the back and pull them tight with the wheel nuts. Don't over tighten them as you will break the new ones
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    SAV_117's Avatar
    VY Lumina
    Jul 2008
    Reaper
    thats how i thought it worked
    VR V6 Manual
    Aug 2008
    2010 Voodoo Sv6
    Sep 2008
    You will need a decent allen key to get the hub off (can't remember what size may have been 10mm? As well as a small sledge hammer to know the allen key....
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
  1. Broken Wheel studs!
    By Uber_Matt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2008, 08:10 PM
  2. Rear Wheel Studs
    By Dowling_s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2007, 08:59 PM
  3. Broken Wheel Studs
    By 089JAY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2007, 11:52 PM
  4. Broken Exhaust Studs
    By Sick Blue VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2005, 09:51 PM
  5. HELP!! broken wheel stud
    By ndatkins in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2005, 08:36 PM
