Results 1 to 9 of 9
Thread: Automatic gear change
    VY 03
    Aug 2005
    Unhappy Automatic gear change
    Hey guys my vy has done 159k's And what i have noticed of recent is that when i take off the gearbox seems to hold out when changing into 2nd gear Its only for about 1.5 seconds but still noticeable anybody have any ideas? It doesn't happen all the time but a fair bit Does it just need a service or some sort of adjustment?? The fluid level is fine. Thanks
    vy ss commodore 5.7ltr
    Jul 2006
    i had simmilar in my vyss, at out 124k and then 148k(roughly) and it was a burnt out 1-2 shift solenoid, could try there with an auto service, took an auto place 2 trys to fix mine and that was after 1st and 2nd gears were recoed, luckily under used car warranty and the solenoid under parts warranty on there work
    VY 03
    Aug 2005
    Well i've got 1 year left on my warranty going to have a look at the paper work and hope its covered
    Jul 2006
    oh ok, cool is it holden warranty or like nation wide warranty?
    if holden you will be ok, if nation wide then id be checking, as iv had a couple of problems with them not covering certain things and others only if you can prove that what they cover is it and not something else on that part.
    VY 03
    Aug 2005
    Its through a car yard. So im going to check up on there's to see what they will cover under gearbox. Thanks for your help
    Jul 2006
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    hope its holden warranty and not one of those dodgy little extended warrantys that come in the blue booklets... **** those things are evil
    SIR LS1
    the two ton go kart
    VY 03
    Aug 2005
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Does your car have a transmission cooler?
    They are good for keeping your tranny lasting longer. My vs did 250,000Ks. Nothing was replaced on it. Just regular servicing.
    Should get one installed if you don't have it already.
  1. automatic gear knobs
    By PEAKN6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2010, 03:32 AM
  2. Automatic Gear knobs
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 08:12 PM
  3. WTB: Holden VY/VZ SS automatic Leather Gear Shifter
    By SIXAPPEAL in forum Swap / Wanted to Buy / Trade
    Last Post: 14-01-2006, 12:42 AM
  4. VN S automatic gear box
    By mmafan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2005, 02:45 AM
  5. Rough gear change
    By veclubby in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2005, 10:15 AM
