Results 1 to 4 of 4
Thread: VY 2003 model Antenna & mast
    VY acclaim
    Dec 2007
    Default VY 2003 model Antenna & mast
    Hi,
    I have Holden commodore VY 2003 model.
    The aerial Mast was broken. So i removed the entire motor unit and removed the mast and cable out.
    By mistake i also opened the gear box of the motor unit and removed the gear.
    After i put back the gears, and installed new mast and cable, the antenna goes up but the motor does not stop after the mast is fully extracted.
    is there any timing for the gears?
    Thanks and Regards
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    As far as i'm aware thier supposed to extend to full length.
    But i could be wrong.
    My old VN was the same. The motor didnt stop till it was fully extended.
    VY acclaim
    Dec 2007
    The antenna is extending fully, however the motor does not stop.
    There is one main gear in the motor unit, which has a small projection which rotates another disc activating the start and stop timing of the motor.
    By mistake i removed the main gear, also rotated the disc, thereby screwed up the timing.
    I played around with the position of the gear and disc by trial and error, but no luck.
    If anyone can give me the diagram for the motor/gear assy which explains the procedure to replace gears, that would be fantastic.
    Thanks and Regards
    VZ Executive Wagon 2005
    Mar 2008
    I have the same drama, the motor just keeps on going after i replaced the arial. I just twist the top of the arial clockwise and it seems to fix the problem for a little while!
  1. is a vt mast compatible with a vz mast?
    By azzaman59 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-07-2006, 04:38 PM
  2. New aerial mast for VT
    By bc77 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2006, 06:06 PM
  3. Power antenna mast
    By SLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2006, 01:26 PM
  4. VY SS SERIES 2 UTE 2003 model
    By Julie in forum Parts And Other Items For Sale
    Last Post: 06-03-2005, 09:18 PM
