Results 1 to 4 of 4
Thread: Oil Leak..
    VY 03
    Aug 2005
    Default Oil Leak..
    Wow another problem. I goes to drive off and see oil on the ground :/ Had a problem before with the rocker gaskets but i fixed that and i checked them out and they are ok. So i had another look and i couldn't find anything i thought it could have been the rear main but it doesn't look like it anyhow here a some pics. post your thoughts Thanks!
    http://james.phreek.org/1.JPG
    http://james.phreek.org/sump.JPG
    http://james.phreek.org/underAC.JPG
    vy ss commodore 5.7ltr
    Jul 2006
    not sure dude, not the engine mount, are they oil filled mounts?hard to tell from the pics, looks like possible rear main, but hard to tell from pics, possible loose valley bolts, had that on my vr v6 after starting with rocker cover gaskets, ended up being loose valley bolts(were inlet manifold bolts to block), could try and see if there loose, better to see when jacked up or on a hoist at local mechanic or holden if bolts are ok and no oil from valley area.
    VY 03
    Aug 2005
    Ill look into that thanks! Ive got the Holden workshop manual so ill look it up ^^
    VY 03
    Aug 2005
    Put a spanner on my valley bolts today and i could tighten them up So this weekend i will be doing the ones in the hard places and hopefully it will stop the leak. Thanks for your help
  1. Bad Oil Leak, Need Help
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2009, 10:20 PM
  2. VS V6 oil leak
    By mcvk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2007, 03:34 PM
  3. Vn Leak!!!! Help
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:05 AM
  4. Oil leak
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 10:37 PM
  5. Oil leak on VS
    By julandi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 07:50 PM
