Results 1 to 8 of 8
Thread: vy lsd??
    vy s pac one tonner
    Nov 2008
    Default vy lsd??
    hey
    i have a vy one tonner and want an lsd for it as it sux to drive in the wet with an open center. wat diff center do i need??
    cheers
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    vy s pac one tonner
    Nov 2008
    CANYONERO's Avatar
    Mar 2006
    Country SA
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by brenton View Post
    hey
    cheers
    essentially another from a tonner, our old work ute one tonner had a lsd and it was only a base model. and a real early vy being an 02 build,
    im thinking the centre may be the same that was used in the vn-vs?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I wouldn't be surprised if it did have one - aren't the LSD's in the one tonners a bit iffy? A fella in town with a s2 s pack went through two in the warranty period granny driving it - admittedly with a hefty load though.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by one_and_only2004 View Post
    they had problems with them clunking, the same with the crewman, i think with holden testing they came down a little bit of backlash was causing the clunk to travel into the chassis and echo, so if backlash was out of spec diffs got replaced, i believe
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    you should look at the harrop site if you want a good quality diff
