Quote:
Originally Posted by Toa
The whirring noise sounds like a noisy thrust bearing.
When your box is cold, try putting the gear lever into 1st gear first and then (without releasing the clutch) across to reverse, this should slow the synchros down and stop the crunching.
the whirring noise is the bearing on the input shaft
and according to Holden (Field Service mechanic) it is normal on the M6 trans
some are VERY noisy...comes standard with these trans
and your solution re reverse..spot on
but I can recommend a fluid replacement as helping here
on the SS, I replaced the tranny fluid with Castrol TransMax Z*
and it got 50% better..not perfect but better
*if you do this, don't forget the trans overfill procedure
hth
cheers
