Results 1 to 9 of 9
Thread: Adjusting front bar
    VY S, SI Hot House Green
    Jan 2006
    S.E. Victoria
    Default Adjusting front bar
    Slightly annoying problem I am trying to fix.
    I am aware there are four clips (two each side) and the screws in the wheel arches that connect the front bar on my VY S pac, however I am finding that it is dipping in the centre. There is a slight gap beneath the headlight (probably 5mm at most) and then below the holden logo also where the bar appears to have dropped a little.
    I have removed the bar and reattached it in an attempt to cleanly reinstall it hoping that would fix it, however it still seems to sag.
    Any tips guys? Will hopefully get some pics in the morning to better describe my wording.
    Jun 2005
    might be different on your model, but on my VN there were two bolts on the reo bar behind the number plate area that held the bumper on
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    HoldrodeoLT's Avatar
    HoldrodeoLT is offline I have no lemon pledge...
    2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
    Aug 2008
    Quote Originally Posted by stocky View Post
    Yeah there are 2 of those platstic skrew's that i swear the devil forged him self...
    Jan 2006
    S.E. Victoria
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    Quote Originally Posted by Metroid View Post
    ok so i take the bumper off, adjust these bolts and reattach to fix dip?
    better off taking a pic and showing us.
    I have problems with rear bar alignment on the clubby, not much i can do about it
    Aug 2008
    Just took this photo.. got the work shirt dirty and everything..haha
    These could be the reason why shes sagging
    Jan 2006
    S.E. Victoria
    K my camera is being a pain, however while the holes are there for screws, there are no screws... hmmmm
    Farlig's Avatar
    Y-Series Clubsport
    Jan 2005
    they are scevits, run down to holdens, grab em they like a buck each or something. but those 2 dont really do much to support the bar and wont cause allignment issues, mainly a support for when you scrub the front bar
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Hi Metroid
    Your "bar" is just a plastic facia, the real bar is the reinforcement behind the facia that bolts on between the front chassis rails with two bolts on either side. Unfortunately, there is very little opportunity to adjust this bar and the facia is simply held on by the screws and clips you have already located, plus the 2 "scrivets" that should be in place in those two holes behind the number plate.
    If your facia is sagging and the scrivets are missing, try replacing them as already suggested. They might be enough to pull the facia up in the centre and give you the alignment you need.
    If they don't, you might have to pull the facia off and see if the reinforcement bar is parallel with the ground and undamaged. It is quite possible to have a stuffed reo bar with a good facia covering it. If it's damaged, it's a pain to straighten as it is high tensille steel and boxed in, so that access to straighten it is virtually impossible. I tried suparating the two skins once but even after doing so, the front face was too tough to belt back into shape. Better off to replace it. New around $120 I think.
  1. Adjusting Headlight Aim
    By r_i_d_a_h in forum General
    Last Post: 18-02-2008, 05:07 PM
  2. Adjusting Bands.
    By J_D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2006, 03:56 PM
  3. Adjusting the clutch?
    By >mayhem< in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 01:41 PM
  4. Adjusting L3 Dash Odo
    By Wingnut0021 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2006, 10:15 AM
  5. Adjusting The Timing On My Vl
    By KOCHY41 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2005, 01:50 AM
