Results 1 to 3 of 3
Thread: Clutch Grommet Help
    2010 Voodoo Sv6
    Sep 2008
    Default Clutch Grommet Help
    Can someone please give me detailed instructions on where the clutch grommet is!!!! I have had a good look under the drivers side but can't find any grommets anywhere...
    And yes, i have done a search and nothing is coming up
    Thanks
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
    VY Exec S2
    Oct 2005
    from the inside the grommet is where you would expect the clutch to be... under some foam looking thing. its easier to find it from the engine bay though. on the left of the engine bay look under the brake booster thingy and the will be a diamond shaped black rubber grommet which is the clutch pedal hole
    2010 Voodoo Sv6
    Sep 2008
    Quote Originally Posted by 392RWkwSS View Post
    Thanks, i found the foam thing but didn't want to remove it to look behind because its so big and didn't know if i'd be able to get it back in there. Will have a look, thanks
  1. Can't refit clutch blank off grommet
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2007, 05:15 PM
  2. clutch kit
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2007, 09:55 AM
  3. clutch cable grommet
    By tsj83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2007, 05:57 PM
  4. Poking hole in rubber grommet for power lead
    By DavidPartay in forum Car Audio
    Last Post: 13-08-2006, 08:37 PM
  5. Clutch cable grommet in firewall
    By Dexn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2005, 11:05 AM
